Question about Ford 555 backhoe
How to repair the leaks on a 555 extend a hoe boom
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
My JCB 310 the extendable boom wont retract
ram problem
or stuck return pressure valve
Mar 04, 2017 | Cars & Trucks
Replace cylinder in bottom boom on hiranger bucket truck
ive heard of folks doing it without a crane but i would not try it , alignment is too critical with getting guides and stops back in and with nothing to move boom that would be too difficult
anyways: suspend boom end with double straps from crane , disconnect hydraulic/electric swivels/plugs at truck end lift end of boom slightly with boom all the way extended straight out , remove acess panel (both sides) at jct of upper/lower boom section . remove C clip one side drive out pin oppisite side (wiggle boom to clear pin) locate stops in lower section boom end unbolt , slowly pull upper boom with crane away take care of hydraulic lines and electric wires set on floor on wood cribbing , locate bottom of cylinder truck end find C clip and pin Might be behind a trim cover that might need to be remove drive out pin also remove bottom cylinder hyd hose connect crane to cylinder end move out a foot or so remove top cyliinder hydraulic hose then carefully slide out cylinider with crane , Note if your valves are not tight and new oil will leak back and cause boom base to sag when you unhook hydraulic hoses , your gonna need to block this up with wood cribbing just in case
reverse removal process to install new one , also i would not just install a new seal (you can) with out having cylinder recromed I'll bet it's rusty thats what tears the seals up
and allways replace entire oil volume in hydraulics your old seal is in old oil not good for the new one
Apr 26, 2014 | 1985 Chevrolet Chevy
Backhoe hydraulic cylinder repair
Get a kit and rebuild cyl.
Aug 28, 2012 | Ford 555 backhoe
J2004 dodge ram 1500 lost all radiator fluid. from hole in small hoes leading from bottom of engine next to radiator inlet hoes. How to repair or fix.
IF BOTTOM HOSES LEAKING WAIT UNTIL ENGINE COOL DOWN DRAIN THE COOLANT SYSTEM IN A LARGE DRAIN PAN. AND REPLACE LEAKING COOLANT HOSES.
Oct 30, 2011 | 2004 Dodge Ram 1500
4 year old Animal. Suction very poor. Have never replaced any parts.3 pets, lots of fur. Am I missing a filter?
it's fixabl. just get a cup ,to put the scruws in & find a spot to work @ & take the hoes off & get ur boom & go outside gentley guid it in to the hoes . dont push to hard, u may c alot of bild up . now go 2 place the belt is located . this is when u get a screw driver,usely a phillups head ,unscrew the cover&clean as much as need & dont do this on the carpet,it sounds harder than it is. cheak the belt &replace if need b. i hope this helps.
thanks
life's hand man
Mar 02, 2010 | Vacuums
Case 580c hyd problems
There may be air in the system. Otherwise the seals are leaking
Jul 03, 2009 | Ertl 580 Super M Series II Tractor
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Garden Logo
90 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
