Question about Euro-Pro 9120 Computerized Sewing Machine
I can't fit the bobbin casing backinto machine front loading please help
2 Suggested Answers
  • 980 Answers
SOURCE: bobbin casing
Wise not to use it until you have the proper slide plate
Posted on Jul 14, 2010
These parts came off on the LS-2220 Brother sewing machine. How do I fix it.
Good that you included the photo...
The 2 pieces look like the hook and the retainer ring that hold the bobbin.
The piece to the left is the hook ... one to right the retainer ring. The bobbin fits into the hook.
There is a diagram below that should help.
The two black 3/4" long levers need to be twisted outward...then put the hook in ... followed by the retainer ring .... and then twist the two levers back.
Generally the two parts will only fit in a certian way to be able to successfully twist the levers back ... could be some trail and error
capture-ndcrf45py13iteczuh5ab3ob-1-0.png I tried posting another diagram but fixya would not upload it ... I will post this answer and then try to add the second diagram
Feb 09, 2018 | Brother Sewing Machines
The directions are very vague about how to thread the bottom bobbin. I have no idea how this is to be done or how the needle will pick it up. Help Please!
you don't thread the bobbin as such
wind sufficient thread on to the bobbin (use the rewind section of the machine )
place the bobbin in the bobbin carrier in such a manner that the thread unwinds anticlockwise
take the thread and pull it around the edge of the bobbin holder until you reach the slot in the holder
pull the thread down that slot and under the flat spring plate at the bottom of the slot
That plate controls the tension of the bottom thread
pull out about 5" of thread and while holding the thread put the bobbin holder and the bobbin into the machine making sure that it goes right in and clicks in place ( turn it to achieve the click
The needle should be fully up for this procedure
now thread the needle and hold the end of the thread while you hand turn the machine in the sewing direction
the needle will go down and if not on the first time will on the second time pull up the bobbin thread
pull that bobbin thread up and place it along with the needle thread under the foot plate and out the back comment if that doesn't work as there may be a bigger fault that can be fixed
May 27, 2016 | Sewing Machines
Not sewing stich
Don't know the make/model of your machine...
The bobbin case has a latch that you need to hold open until it is in position. When you let go of the latch, it should be secure.
Inserting the Janome Front Loading Bobbin Case
Here's a manual for your machine:
http://www.singerco.com/support/instruction-manuals/search
http://www.getcrafty.com/forum/share-craft/8131-help-big-problem-singer-7033-sewing-machine.html
https://www.reddit.com/r/sewhelp/comments/1kcovm/singer_7033_bobbin_thread_wont_stitch/
Apr 07, 2016 | Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
How to put a spool backinto machine
If it isa top loader the thread goes in so it unthreaded clockwise. If bobbin goes in under the foot by removing the front arm panel slide then the thread goes into the bobbin holder so it unthreads by having thread go through the feed pulling up from your left hand side. This enables the tension to be balanced and not cause binding issues.
Feb 22, 2015 | Brother LS-2125 Mechanical Sewing Machine
My machine is not stiching
try changing the needle--make sure it's the right needle for the fabricdo you have a manual for the machine?
try rethreading the machine top and bobbin
if the bobbin is top loading make sure it's turned correctly
if it's front or side loading bobbin makes sure the bobbin is inserted
correctly in the bobbin case and then make sure the bobbin case is
inserted correctly into the sewing machine.
clean under the needle plate and in the bobbin area for lint
let me know if these suggestion help or not
Nov 17, 2012 | Sewing Machines
Singer 2263 needle hitting something in bobbin area (loud thunk) and needle moves
try taking the bobbin out and putting it back in the bobbin
case if it's a top loading bobbin
if it's a side or front loading bobbin make sure the bobbin case is
inserted correctly
if the bobbin and bobbin case are inserted correctly then
it sounds like the sewing machine could have a timing
problem and needs to be checked at a sewing machine shop
Nov 12, 2012 | Singer 2263 Mechanical Sewing Machine
I have been sewing bunting for a copule of days without trouble. When I changed my bobbin and spool, the bobbin thread gets caught up and makes a mess and stops the machine. Also, the bobbin case doesn't...
Is this a top loading bobbin case? If so take the stitch plate off and look for burs or needle punckers on the bobbin case, if you find some polish them off(may need to be replaced.
Also did you use the exact same bobbin that you took out, just had a customer come it that was using the incorrect bobbin for her machine.
Also check your top threading, sounds like it could be that. Make sure to get it in the tension unit. Thread the machine all the way to the needle but not in the needle eye. Then lift and lower the presser foot, you should have tension when it is down and no tension when it is up. If not your machine needs adjusting.
hope this helps
Mar 18, 2011 | Toyota Sewing Machines
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
Can't remember how to load the bobbin
If you have the seperate bobbin case that goes into the raceway, that is the bit which should have a black clip either side, make sure the needle is at the top , with the two black clips open the gate can be dropped down or taken off, the half moon shape shuttle should fit in quite easily, put the gate back up and put the clips acrosss to hold it in, take the bobbin case by the latch with thumb and forefinger and pop it in.
Jul 22, 2010 | White Sewing 1415 Mechanical Sewing...
Euro-Pro 9120 Computerized Sewing Machine Logo
19 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
