Question about Graco Pack 'n Play
How to fold up a pack-n-play - Graco Pack 'n Play
I'm tryin to take down my Eddie Bauer pack n play!
Some of these Pack n Plays are double jointed where you fold the sides. Feel around the buttons you release the sides with and see if there isnt a release button on each side of the joint. Remember, all Pack N Plays use a safety on the floor of the playpen that must be lifted to allow the sides to fold. I think you have already done that but the second release button is holding you up.
Feb 10, 2012 | Eddie Bauer Baby Gear
How do I to fold a safety first pack n play?
This is not a product available in the UK so we are unable to assist. Please contact your retailer for assistance.
Dec 15, 2011 | Safety 1st Disney Care Center Play Yard...
We cannot breakdown our pack and play. How do we get the top rails down?
In order to break down the top of your Graco Pack 'n Play, you must find the middle of the bars. It's easiest to collapse the the shorter ends first. The middle of the bars should have a nodule. Squeeze that nodule and pull up on the side, sometimes you may have to do this firmly and **** the side. When the first side collapses, repeat for all sides. Once they are collapsed, pull up on the bottom of the Pack 'n Play, and it will fold together.
Dec 07, 2010 | Graco Pack 'n Play
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How cani open graco play pen
To open the Graco Pack 'n Play from the folded position, you have to latch each side rail by pushing the two ends of each rail until they are horizontal and form a straight line. They will latch into place with an audible snap -- do this for each of the four sides. Then push the center of the Pack 'n Play's floor down until it is flat as well.
If you can't latch the side rails, the floor of the Pack 'n Play might be down too far. Push the floor up until its center reaches at least halfway up the sides of the Pack 'n Play. (You can do this by pushing the sides of the Pack 'n Play in toward each other.)
Were you able to open it using these instructions?
Jun 24, 2010 | Graco Pack 'n Play
I can't get it to fold down to store it
I had the same challenge. If you pull the center of the pack and play up at the bottom inside up the side latches should release for you to be able to fold it up.
Mar 22, 2010 | L.A. Baby Play Yard 89
Folding up Cosco play yard
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
Hope this helps!
Jan 06, 2009 | Cosco Beatrix Potter Playard Crib
Graco Pack 'n Play Logo
23 people viewed this question
Top Graco Toys Experts
Shehu Pro
Shehu Pro
ray gallant
George Persico
George Persico
Are you a Graco Toy Expert? Answer questions, earn points and help others
