Question about Motorola Mobility RAZR V3
Open/close screen sensing issue
Every now and then when i pull my phone out of the case the outside screen shows the picture it show when it is opened then shows the time like it was opened then closed. then today I set the phone in my lap while it was opened and the inside screen went white and it acted as if it were closed. how do I stop this from happening?
  • rustyk123 Dec 07, 2008
    ok i have solve my own problem and an posting it to help others. remove the battery cover, battery, and SIM card. the piece of metal that covered the SIM allows the SIM to move to much just press down on the metal to form a tighter grip on the SIM
  • 72 Answers
Theres a problem with the ribbon cable inside your phone if its a sliding or a fliptop unit you need to tighten the connection or replace it. or if you don't like to open ypur phone by yourself just go to your nearest cellphone technician, he can take care of the problem.
Posted on Feb 15, 2008
SOURCE:
The front screen of my Nokia 2720 is just blank, how do I get to work
The micro ribbon wire may be damaged if its blank if the phone is old this may be the case opening and closing breaks the ribbon wire after time. If it is new return for replacement. also in menu, phone, display is where all adjustments are.
Apr 06, 2012 | Nokia 2720 Fold Cell Phone
1998 Toyoto Camry Door doesnt not open from outside
Either the handle is broken inside the door, or the clip that holds the actuating rod is broken. If it either of these is shouldnt take any more than an hour to fix.
Jun 05, 2009 | 1998 Toyota Camry
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
When closed, the outside screen does not light up.
Took battery out and turned back on. I guess maybe should power up and down every once in a while, it might reset things. Ended up no big deal. thanks.
Jan 16, 2009 | LG CU500 Cellular Phone
Processor
Not showing on the screen in the sense, is the Operating System [assuming XP] system properties window not showing the processor details? If its the case, generally some processors will have some issues with the Operating system.You can fix it by downloading some "hot fixes" from Microsoft.
Try this: 1.Open the "run" dialog box [Windows key + R] 2.Type "dxdiag" [without quotes] 3.Press enter. 4.You will be able to see the processor configuration in that window.
If not succesfull, please post. I will suggest another method.
Oct 29, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
RAZR V3M thinks it's always open - Screen will not turn off
in the top right corner you are suppose to have a little circular magnet that changes the screen when the phone is open or closed. I just changed my housing yesterday and took the magnet out and put it in my new housing but for some reason i have the same problem as you. so maybe you lost the magnet when you replaced the lcd and if that is the case then you are screwed. try have Motorola fix it, don't tell them you replaced the lcd
Dec 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
My phone shows a white screen
lo m8 sounds like it could be a problem with your ribbon.try opening the flip and closing it.if by doing this it sometimes works and sometime does not work then its your ribon that needs replacing.if you dont want to do it your self then send it to these guys they very cheap an do most my repairs to a good standard. http://www.mobilephoneservicecentre.co.uk/
Aug 01, 2007 | Motorola Mobility RAZR V3
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
63 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
