Question about Black & Decker BL5000 ProBlend Work Top Blender
The motor spins but the blades not - Black & Decker BL5000 ProBlend Work Top Blender
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 | Blenders
My wolfgang puck 1.6 hp professional blender will not spin the blades if there is anything in the blender container.
This is not really the solution it is just a better description of the problem that I am also having. This is a great blender however the part where the cup blades conect to the motor is made of plastic.
So what has happened here is that the motor is fine, the cup is fine only the plastic part that makes the motor turn the blades has worn down therefore rendering the blender useless. I would like to know where I could get this small part to change on my blender!!!
Jul 30, 2012 | Wolfgang Puck 1.6 Hp Professional Blender...
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
Blade on MD95 not spinning
The shaft has probably siezed at the bottom near the blade. The seal can fail and let liquid inside the shaft and gunge it up.
Take the orange handle apart, then unscrew the four steel pins, then pull out the motor. From the blade end, take the screw from the blade and prize it off. Then pull the shaft out from the top and clean it. It may be stuck - push a blunt nail or similar in the bottom to free it. Clean the shaft and solidified debris inside the tube. Then reassemble carefully.
Feb 14, 2012 | Dynamic MD95 Handheld Blender
Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
May 02, 2010 | Blenders
A blade on my immersion blender was bent slightly. The motor still works and the blades spin, but they no longer emulsify. Can I buy just a new blade attachment?
If you have a model with the detachable blades. Otherwise, you'd need to purchase the blending rod from www.wpcookware.com.
Jan 16, 2010 | Wolfgang Puck Immersion Blender
Motor works but blade not spinning
Check and make sure that the shaft in the base housing spins. If it does, the blade assembly has become disconnected from it's shaft probably due to an improper spot weld or peening of the blades to the shaft, or has torn loose or ripped the splines out due to an immovable object trying to be spun. A jammed ice cube can do this. Blade assemblies can be had usually directly through the manufacturer and usually on line. If this has helped, please rate it accordingly.
Jul 20, 2009 | Westinghouse 0101 IntelliBLEND¿ Work...
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Blades won't turn
If the problem is that the blades are jammed and you can't turn them manually, you can let it sit ( and dry out ) for a few days, or you can try adding some oil. I had the same problem and this worked. My problem now is that the blades don't reach to where the motor is turning, so even if they're not jammed the don't turn. If anyone knows and answer to this I'd appreciate it.
Jan 24, 2008 | Oster 6678 14 Speed Blender
Black & Decker BL5000 ProBlend Work Top Blender Logo
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
