Question about Welding Tools
Looking for carb on my Kawasaki KF150D-SX . Engine is great just need to replace the worn out carb but can't find a replacement . Any leads would be appreciated. Tks
chose one
SOURCE: dvd works great ,need to replace power socket ear phone socket
sorry my mistake, I was trying to find afree service diagram to help me change a worn power socket in grandson`s cyberhome portable dvd model ch-ldv 700b. Thanks
Posted on Jul 18, 2008
  • 109 Answers
SOURCE: Replace Front seats in 1994 Bronco
F150 seat should work in the 94 bronco if not you could remove thebraces and sliders of the bronco and put them on the other seats..
Posted on Dec 02, 2008
  • 9 Answers
SOURCE: won't idle steadily
Check the rubber boot that joins the carby to the engine to often have seen the hose clamps over tightened therefore creating a split in the rubber letting to much air in giving the rough idle eventually you wont be able to start it at all (have a good thorough look inside an outside of boot doesnt take much)
Posted on May 22, 2009
#1 Taper
  • 1040 Answers
SOURCE: SX-135 Homelite trimmer-carb diaphram cracked
You can go to an outdoor power & equipment type of store (Independent store). The cost is around $12-$18.
Jim
Posted on Jun 19, 2009
Sparko1
  • 167 Answers
SOURCE: Looking for Replacement screen For 52" RCA Projection HDTV
You should call a few TV Repair shops. They will have a few of these TV's junked for parts. They will sell you a screen for cheap.
Posted on Jul 31, 2009
I have a 1994 Kawasaki Vulcan 88. Accelerate off idle and it shakes bad, continues through the rpm range until its a vibration, plugs don't look bad, carbs cleaned, it only has 15,300 miles on it.
Hi, Jim and the usual suspects are:
1. Wheels and or tires worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain is badly worn or links too tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect due to a poorly tuned engine.
7. Internal engine problem flywheels have shifted.
8. Broken frame.
9. Stabilizer links worn or loose.
10. Rubber mounts loose or worn.
11. Rear fork pivot shaft nuts loose.
12. Front engine mounting bolts loose.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1994 VN1500 Bad Engine Vibration
bad engine balancer caused vibration fixed now with pics
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki/kawasaki-vulcan-owners-manuals
Feb 11, 2017 | 1996 kawasaki VN 1500 Vulcan Classic
I have kf150d -sx auger engine weak yellow spark
Yellow spark could mean a weak coil or bad condenser. Try replacing condenser first and be sure points are clean and adjusted. If does not have points, is electronic, clean the flywheel at the magnet on the flywheel and set the air gap to specs between coil pickup and magnet.
Oct 11, 2014 | Cars & Trucks
My 1998 Kawasaki jet ski is sluggish on take /
Probably need a fuel system clean out and or a new carb. Also check engine compression and make sure it is at minimum psi. The reed vales between carb and engine may worn out. To be honest, since its so old it is probably time to consider replacing it or rebuilding the engine if hull is in good shape. You may not be able to even get the parts for it.
Jun 29, 2014 | Garden
Husqvarna with Kawasaki 21hp engine misfiring when revved
We had big problems with the Kawasaki engine doing this, the early engine has an external vented carb, you can try extening the pipe from the carb and get it away from the draught from the flywheel, the later engine has an internally vented carb which cured this issue, the carb is retro fittable but expensive, it was offered as a re build kit when fitted to Husqvarna tractors, try taking it up with Kawasaki.
May 29, 2013 | Garden
FC420V Kawasaki back fires thru carb on cold start,runs and starts fine after difficult startts
It sounds like your valves may need to be adjusted...
if they are too lose or worn they won't seat properly and when the engine fires it blows back through the intake valve.
pull the cover and see if the rockers are loose... it only takes one to give you a headache.
Mar 29, 2013 | John Deere 420,1020,2010,2020,2510,2520...
KTM 105 SX spark plug fails every ride???
Hi, Sagi nice novella and the usual suspects are:
1. Fuel mixture too rich or enrichner left out too long.
2. Faulty spark plug.
3. Incorrect spark plug for the engine type or service.
4. Piston rings badly worn or broken.
5. Valve guides are badly worn and/or seals worn, crushed or have come off the valve guide and are pumping oil through it.
6. Spark plug cable weak or leaking check for spark jump in the dark.
7. Faulty ignition coil.
http://www.ktmforums.com/forums/two-strokes/1966-solution-fouling-spark-plugs.html
Why Does My Dirt Bike Keep Fouling Spark Plugs
KTM 85sx 105sx service manual repair 2004 2009 85 sx 105 sx Download... $8 cheap
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 85 105 SX Owner Manual
Mar 11, 2017 | 2007 KTM SX 105
How do i sync carb on 1995 kawasaki zx 6oo
Hi, you will need to get yourself a set of vachume gauges, you will connect 1of these gauges to each of the vachume pipes on each cylinder on the carb inles maniflold.you will run up the engine to normal temp having first replaced any worn spark plugs,it is not ness to get all of the hauges reading exactly the same while the engine is running, 1 increment indifferance would be allowed if you cannot reach exactly the same. The tickover screw addjusts number 3 carb, and the rest are fine tuned by the spring loaded screw between the other carbs, if they are close enough when you check them initialy, leave them alone and recheck at a later date, hope i have explaned to your satisfaction, not a job for the faint hearted, any probbs contact me and i will reply on earlyest convenience, paul
Oct 31, 2011 | 1999 kawasaki ZX-6R Ninja
Kawasaki zrx400 import, carbs are varnished up, 1994 model. Any ideas on replacement/model compatible part would be great.
dont replace them unless you really just want new carbs take them off and spay them down with carb and choke cleaner
Sep 14, 2011 | 1989 kawasaki ZXR 400
One carb does not want to fuel on low revs ie remove plug lead from good pot on low revs it stops remove plug lead on good pot with revs it wiil run remove bad plug lead on low revs makes no change to...
Sounds like you need to remove the carbs and dismantle them and clean all the parts real good.
Remember if you separate the carbs from each other you will need to resync the carbs.
Oct 16, 2009 | 1997 kawasaki ZX-6R Ninja
Fb460v kawasaki will not start
check your camshaft to see if exhaust loab has been worn off. have seen this before
May 01, 2009 | kawasaki Full Suspension Mountain Bike Men
Welding Tools Logo
105 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
