Question about Fisher Price Space Saver High Chair
How do i get the straps off to wash them? - Fisher Price Space Saver High Chair
I removed harness to wash and have refitted shoulder straps but adjustment ******** Viaggio Primo SIP wont thread through and under buckle . can you advise please
To figure out how to do this with the Peg Preggo Viaggio Primo SIP, I think it's best to contact their customer service:
1-800-671-1701. Customer service hours are Monday - Friday 8am - 4:30pm Eastern time.
Feb 10, 2013 | Baby Gear
Hi can i remove all the harness straps from my maxi cosi priori xp to wash or replace them?
Please do not wash your harness straps, they should not be submerged in water only spot cleaned.
If you have already washed them or just want to purchase replacement straps they are available on the last page of your manual.
I found an online copy of the manual here as well in case you have misplaced yours:
http://tiptoeturtle.com/assets/product_files/instructions/Maxi-Cosi/MaxiCosi_Priori_manual.pdf
Mar 07, 2011 | Maxi-Cosi Priori
Cant remove the cover off the straps at the bottom of the cabrio fix car seat i have removed it off the seat but can not remove the straps at the bottom to remove the cover
Had the same problem where you are left with the cover trapped by the quick adjust part for the shoulder straps located near the foot of the seat. The solution, the strap does detach at the front of the seat. The loop that is stiched round what feels like a solid plastic part of the base, turns out that there is a gap in the plastic so push the strap to either side and pull it out through the gap. With this removed you should now be able to remove the cover completly and bung it in the washing machine on a hand wash.
Feb 16, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
I am having trouble adjusting shoulder straps
Funny, I was just putting this seat back together after taking it apart to wash it. It is a very difficult process, simply because you have to remember which order to loop the buckles through the stap.
First, I assume you want to switch from the lower holes for the shoulder, to the upper. (If not, then there is no adjustment needed. Unless the strap is caught in the back which will make the straps uneven when you go to tighten them. This has happened to me).
So, first you need to remove the straps. Once the seat is removed from the car, look at the back of the seat and you will see a metal bracket that is holding three straps. The bottom strap is not removable from that bracket. The top two strap are attached to the bracket with loops. Remove the straps by sliding them out (edge of the strap has to come out the hole first, then the rest will slide out very easily), Once out, from the front of the seat, pull the strap through the holes
At this point you must decide whether you simply want to adjust the seat, or wash it too. I highly suggest washing it if you haven't done so recently. If you gone this far, go all the way. But since you only asked to adjust it, and the method for removing the cover is much more complicated, we''ll move on to adjusting
Now that you have the straps pulled through, be sure that the straps are not twisted, and simply push them through the desired holes - upper or lower - and reconnect to the loops brace (remember, edge in first).
If you are having problems with the straps not being even when tightened (one side tight on shoulder, other side loose), remove the seat and look to see if the strap is caught on something.
I'm retiring my seat today after six years and two kids. I could use it up to 80lbs, but it makes it difficult to get to the third row of seats in my car. So now we have two no-back boosters.
Oct 13, 2009 | Eddie Bauer Deluxe High Back Booster...
HOW DO THE STRAPS GO BACK THROUGH THE LATCHES? WE WASHED THE SEAT COVER AND WE CAN'T FIGURE OUT HOW THE STRAPS WERE THREADED TO LATCH THE BABY IN THE SEAT
Your not suppose to wash the cover...as bad as it sounds you are suppose to spot clean only... after you remove the cover their not safe any more.
Sep 23, 2009 | Eddie Bauer 3-In-1 with Latch
Evenflo carseat,can't figure out the straps after washing
You need to put the straps throught the bottom, then the top openings you put it through the 2nd **** or where the baby will be comfortable. Then you tie it on the back.
Jun 17, 2009 | Baby Gear
Need help rethreading safety strap
My son has special needs so I must wash his seat often. I can not remember how to put the straps locks back so...
First, whenever I wash the car seat cover, I rethread the straps immediately. I only unhook one at a time and look at the one that is still threaded to see how to re hook the one I am working on.
Since you can't do that at this point, I suggest going to a store that sells car seats, look at how the straps are hooked and if you have a picture phone - take a photo!
May 14, 2009 | Baby Gear
Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
May 08, 2009 | Century Encore 5-point Harness
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
I have a 02-442-PRI 11-17-98 Cosco
If you washed the straps, they will need to be replaced. Lock the harness together, to prevent the straps from being twisted. Feed the top part of the harness through the slots that are AT or ABOVE your hangchilds shoulder if the seat is forward facing. IF the seat is for rearfacing, feed the top part of the harness straps through the shoulder slots at or BELOW the child's shoulder. Once each is through, reach down and attach them to the silver plate that hangs from the **** strap adjuster. Once you silde each of the harness straps, then slide the bottom of the through the hole in the cover, then into the base of the seat, folding the top like a triangle makes it easier to get through the tight holes. Repeat on the other side and you are ready to travel! Thanks!
Jun 16, 2008 | Cosco High Back Booster 22-200 /22-207
Fisher Price Space Saver High Chair Logo
51 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
