Intertherm e3eb 015h
Buzzer comes on when I turned on the heater
3 Suggested Answers
SOURCE: Fan Only Won't Work
I jumped the rc and rh wires in the therostat box and now have fan only when selected.
Posted on Jul 02, 2008
  • 1015 Answers
SOURCE: the blower turns off but
It sounds to me like you have a transformer that is going to need replaced before too long.It is normal for a transformer to make a low humminig/buzzing sound that you describe but as they get older sometimes they get quite loud.The good thing is they are not hard to replace nor are they very expensive.
I have seen them just be loose on their mounting screws and you might get by just tracing the sound down and tightening the screws. Thank you and good luck.
Posted on Feb 11, 2011
E3eb-015h. What size are the filters?
do you not own a yard stick or tape measure .
Nov 15, 2015 | Intertherm Heating & Cooling
I have intertherm e1eh-015h I just wired up heat
when the thermostat is set more than 2 degrees higher than room temperature the auxiliary heat will run with the heat pump.
Oct 11, 2014 | Heating & Cooling
My intertherm e3eb-015h electric furnace will not do a thing even temp.on thermostatdont show up breakers are on still nothing
Check to see if the fuse is blown. If it apprears to be blown, replace it. It is inexpeisive and simple. If you locate the fuse, you will be abel to determin if it is blowin becuase you will be erruption or a burnt mark in the fuse wires.
Sep 21, 2014 | Heating & Cooling
I have an Intertherm e3 series modle # e3eb-015h it will cool at around 82 degree but is now Icing up so I have to keep shutting it off, at first it only did this after a long period of not running the...
Hello my name is Heath it will be my pleasure to assist you. First thing to do is turn the unit off and check the filter then if the filter is okay check to see if the blower comes on when you put the fan switch on the thermostat from auto to on. If the blower isn't coming on then there could be a problem with the blower motor. If the motor is running then turn the system to cool and turn the setting down to where the air should be on. Then check the outside unit and be sure the outside unit is running if the outside unit is not running go to the house panel box and check the breaker to see if any of them are tripped or off. If there off turn them on and check the outside unit again. If all is running and you get no air flow through the vents then the coil could be frozen. If the unit is frozen turn the thermostat to off and leave the indoor blower on by leaving the fan switch in the on position for a couple hours till it thaws. If the unit froze up then there could be a problem with the a/c system most likely low on refrigerant as a result of a leak. I would have it leak tested and repaired if this is the case.
Sep 10, 2011 | Heating & Cooling
The blower turns off but the unit keeps making a loud humming/buzzing sound intertherm E3EB-015H
Feb 11, 2011 | Intertherm Heating & Cooling
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
Fan Only Won't Work
Jul 01, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
