Question about Tour Trek One Click 2.0 Collapsible Push Cart
Where can I get a new brake wheel for my Tour Trek One Click 2.0? The nubs for the brake have worn off.
Where to i get replacement parts for Tour Trek collapsible golf cart
contact golf supply shops
get the manufacturer web page up and check for spares
Aug 21, 2014 | Tour Trek One Click 2.0 Collapsible Push...
What is the front wheel size of trek 3700 ?
Rotate your wheel so that the valve is in the 6 o'clock position, mark where it is on the ground and roll the wheel along the ground 1 complete revolution (until valve reaches the 6 o'clock position again), mark that and measure between the 2 marks.
Aug 15, 2014 | Trek Cycling
Brakes on trek 7300 locked up, how do you release?
Well, if your bike has been stored outside, then the cable is corroded in the housing. They will both need to be replaced. If the brake pads are wedged against the braking surfaces of the rims, then they were either not installed correctly or the pads have worn enough that they make contact at an odd angle and became stuck.
Jun 19, 2014 | Trek 7300
Need to adjust front brake pads
There is an adjuster where cable enters brake caliper
Also you could loosen mounting bolt. Realign and tighten.
Apr 09, 2014 | Trek 3700
When riding the peddles slip,it appears that the chain is engaged and that the axle is slipping and make s the peddles spin, not engaged
If this is a coaster brake bike (single speed, no hand brakes) then the problem might be inside the rear wheel hub. If that is the case then you can only fix it by completely dis-assembling the rear wheel hub - or it might be simply that the chain is slipping, which would not happen unless the chain is too loose which would be indicated by the bottom of the chain hanging down too low. However, if this is a multi-speed bike, then it could be that the chain and rear-wheel cogs are worn - which can be fixed by replacing the freewheel and the chain - however, it takes a lot of use or rust and dirt before that level of wear happens.
Aug 07, 2012 | Trek Mystic 16
UNABLE TO DISENGAGE REAR BRAKE LIGHTS
the rear brake lights work off the brake light peddle look under the dash at the brake light switch to see if it is unplugged or broken
Oct 12, 2010 | 2000 Nissan Xterra
2007 Royal Star Tour Delux with 15,000 miles Rear brake issues.
No you should have from time to time safety checked your motorcycle, brakes are a normal wear part and should have been replaced before the friction material had completely worn off.
May 24, 2010 | 2007 Yamaha Royal Star Venture
I HAVE A 125L HUSQVARNA TRIMMER. THE RECOIL STARTER WAS FINE, THEN STARTED MAKING A RATCHETING SOUND SOME OF THE TIME BUT WOULD NOT PULL THE ENGINE THROUGH AND START IT OTHER TIMES, NOW IT MAKES THE...
Actually, there are two solutions, did not see the two nubs on parts diagram either but I have done some extensive research and the nubs come with the cup assembly. One solution is to go to partstree.com and order part # 545102303 or part # 545180844. Both come with the white plastic nubs and springs. Also, what I did with mine if you are tech savy is cut off the stem that goes through the black cup, drill an 1/8th in hole through the bottom of the plastic nub and then assemble nub and spring and secure putting a screw through the hole in the bottom of the black cup, securing the nub. All you are doing is replacing the part of the nub that goes through the plastic cup with a screw. You are pre drilling the hole in the nub so you dont crack the nub with the screw. Make sure the screw is straight so you dont get too close to the edges or it will crack. This method takes crafty hands and good eyesight. If done correctly, they will never pop out again. Promise!
May 09, 2010 | Husqvarna 28cc Gas Line Trimmer
I have a nasty grinding in the front end of a 96 buick skylark that makes it sound like a train any ideas
brakes or wheel bearings, a shop should be able to diagnose one or the other, maybe both.
Sep 30, 2009 | 1996 Buick Skylark
Tour Trek One Click 2.0 Collapsible Push Cart Logo
Top Tour Trek Golf Experts
Ronald Prier
Bill Boyd
Tom Chichester
Are you a Tour Trek Golf Expert? Answer questions, earn points and help others
