Question about Mitsubishi DD-4000 DVD Player
How to hook up to cable - Mitsubishi DD-4000 DVD Player
I have a 98 isuzu rodeo and my friend hooked up the jumper cables wrong one day and now none of my dash lights or any of the switches on my dash work (4x4, cruise control, etc.) and it's stuck in 4x4
What can be damaged by hooking jumper cables up the wrong way ...
https://answers.yahoo.com/question/index?qid..
May 3, 2011 - My car battery was dead so we asked someone for a jump and when we tried starting the car, the negative jumper cable on my car started ... what happens when you hook up car battery cables wrong?
Apr 12, 2013
Hooked jumper cables up wrong and radio won't work, why?
May 26, 2010
Hooked up jumper cables backwards now my car wont start no ...
Apr 2, 2009
What happens if you hook up jumper cables backwards on a car ...
Oct 4, 2008
More results from answers.yahoo.com
Do not connect your jumper cables backwards or bad bad ...
https://www.reddit.com/.../do_not_connect_your_jumper_cables_...
RedditOct 25, 2012 - Do not connect your jumper cables backwards or bad bad things ...What I'm trying to say is, does this usually happen when you hook the cables upwrong? ... So basically there is only one way to find out for sure what going to .
Oct 16, 2015 | Isuzu Cars & Trucks
When hooking amp directly to battery, you hook battery hot cable and power hot cable then hooking ground cable up the ground cable becomes hot and pops the fuse
your amp is bad. you should have a 12v, ground, and remote wire. if these are hooked up correctly, your amp is more likely broken, and needs to be repaired or replaced.
Jan 30, 2011 | Car Audio & Video
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Feb 02, 2009 | iLO 3200 32 in. LCD Television
Cable hook up on tv is broke. trying to hook cable up to jvc dvd
Some times you can try tapeing it on (Black tape). Thats what i had to do one time.... It worked.
Jan 25, 2009 | Curtis-Mathis CM27101S TV
Coaxial cable hook up
You have to buy a adaptor for coaxial to television antenna hook-up. One side is used to hook up the cable to and the other side is to hook up to you televisions antenna's screw hook-up. These adaptors can be bought in most electronic stores and you should be able to find them on line. Just use google for cable to television adaptors. I hope this helps you with your problem.
Aug 26, 2008 | TruTech PLV16320 Television
Antenna input
How do I hook up the HDMI cables to a cable box
how do i hook up hdmi cables to cable Sony KDL Bravia LCD HDTV
Jan 19, 2008 | Televison & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Hooking up cable through ht-x50
You need an Optical Audio Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
Dec 05, 2007 | Samsung HT-X50 System
Pip
Take the cable wire that hooks to the IN connector on your cable box and hook it to the IN connector on a 2-way cable splitter.Get 2 more short cable wires and hook one end to the OUT connector on the splitter and the other end to the IN connector on the cable box.Take the other short wire and hook it to the other OUT connector on the splitter then hook the other end of this wire to your tv (you must have two sets of RF connectors on your tv for this to work)Or you can tap the A/V connector off your cable box hooked to a video input on your tv.
Aug 19, 2007 | RCA P52930BL 52" Rear Projection...
Mitsubishi DD-4000 DVD Player Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
