How To Take Apart Gould JL07N - Televison & Video
How to replace impeller on guolds j10
What is the make and model of the "pump"?
Gould is a motor manufacturer.
The manufacturer of a pump, will use a third-party vendor like Gould, to provide them a motor for their pump. Gould is Century/Magnetek, which is now AO Smith.
BUT...
remove pump housing/volute covered, and access the impeller. Then on the back of the motor you should be able to access the shaft. Lock up the shaft so it does not spin, and then unthread the impeller. Some pumps, especially two speed pumps, will have a locking screw in the center of the impeller. That screw will be counter threaded or backwards thread. It keeps the impeller from spinning off the shaft during normal operation between high and low speeds.
again if we had more specific information, we would be able to assist you better.
Feb 09, 2015 | Pool & Spa
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
Incorrect email address
Click on your username in the upper-right corner and select "My Profile". You may then change your email address and any other data.
Apr 02, 2013 | Computers & Internet
My gould pump won't cut off after 40 psi
As the pressure TANK only holds the liquid under pressure, you now have two good tanks.
Did you adjust the pressure switch or check it for operation?
Either adjust it or change it with a known good one.
Sep 05, 2012 | Karcher SEAL, CARBON 10K18 GOULD PUMP
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
Only has red and green
The Blue CRT Driver Board gould be the problem.
Jul 06, 2009 | Hitachi 50GX49B 50" Rear Projection...
Gould Water pump Problem
sounds like cavitation in the pump due to the introduction of air. Check for leaks or cracks in the suction line so air isnt being induced into the pump.
Dec 19, 2008 | Plumbing
15 amp Gould breaker trips every 24 to 48 hours
As seemingly with everything else, these devices were once very reliable but now fail early in life.
Assuming that this is no GFI (Ground Fault Interrupter) equipped breaker, you must  have a bad one. If it is, you may have some stray currents tripping the breaker.
While finishing up on our new home and putting breakers in the main box for the first time, one brand new breaker refused to stay set even though the circuit was OK and no loads on that branch connected at all. In the two years we have been here, we had to replace a second one acting just as you describe.
Dec 15, 2008 | Ace Hardware Hi-Tech Circuit Detective...
My tv no pic
your vertical output IC could be faulty, or the FET that controls the vertical output could be faulty
Jul 20, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
