Question about AIRBORNE FUELPUMPS & VALVES Retail Supplies
How to replace fuel pump on 2.4 ltr efi Toyota hiace 2001
Caesarfix
  • 141 Answers
SOURCE: Toyota Hiace 99 Fuel filter change
Look first right rear back under fuel tank,< If not, follow fuel lines from fuel tank one main line, one return line, traveling parallel to frame all the way to the motor compartment on front, can be front under right passenger side, first by the filter at the auto parts, that way you will know what to look for
Posted on Jan 21, 2009
  • 59 Answers
SOURCE: toy turns over but wont run change fuel filter n fuel pump still
The fuel pump should run for a second or two when you first turn the key on, but then shuts down to prevent the engine from flooding if the computer does not get a signal from the crank or cam sensors which the computer uses to trigger the ignition system. So no spark no fuel. Check to see if you have a spark in the ignition system.
Posted on Aug 28, 2009
toyotahelp
  • 390 Answers
SOURCE: need location of the fuel pump relay on a 1990 toyota pu, six cylander 4x4
The Feol pump/circuit opening relay is located inside the cab on a relay block either behind the glove bosx or the right kick panel, I'll see if I can locate a location diagram and post it in a follow up. In the meantime locate the diagnostic check connector under the hood,it's located near the right fender on a fuse block, open the cover and put a jumper wire between the terminals FP and B+, turn the key on and let me know if this makes the fuel pump run.
Posted on Oct 22, 2011
  • 311 Answers
SOURCE: 1991 toyota 4runner efi fuse keeps blowing
Correct pump for the truck?
A blown fuse means there is too much current draw from the pump.
Why is the tough question.Pinched wire?
If the fuse does not blow,immediately,can you measure the current draw at the pump in put wire?
Be SURE to cycle the key on for 5 seconds,off for 2 and back on for 5 seconds 3 times! Prime the pump.
If not primed,properly the new pump may burn out.
Sorry.
Posted on Feb 22, 2013
  • 311 Answers
SOURCE: 1991 toyota 4runner keeps blowing efi fuse after changing fuelpump
See my post,earlier.
Wher is the fuel pump reset button for a 2001 Toyota Sequoia?
doesn't have one . check EFI relay and the fuel pump relay ! Do you have a owners manual . If not google location of relays ,also test for B+ voltage with a DVOM - digital volt ohm meter . Videos on youtube , testing relays and basic automotive electrical testing . How To Fix Toyota That Died on The Road
Feb 12, 2017 | Toyota Cars & Trucks
My Toyota hiace 3L when l start it idle normal but later it start raving on its own as if someone is pressing excelarator what could be the problem?
its a diesel ...this is the 2 ltr motor for an L3
when was its last service ?
is the idle adjustment knob in the cab on start up ok
then you wind it back
could be a vacuum issue/ sticking throttle cable
fuel pump problem /injectors
air filter
how old are the glow plugs
Sep 09, 2016 | Toyota HiAce Cars & Trucks
Hiace Grand Cabin G 1997 1Kz Efi Tubro car fuel consumption is more than normal
get a tuneup.
or scan it for loose of closed loop operation, (USA CARS)
at idle
at flat ground cruise, right foot steady.
if CLose loop fails we fix that first. ask.
Jan 02, 2014 | Toyota Cars & Trucks
Cant get power to fuel pump 1994 toyota truck
why guess.?
ever seen a volt meter,?
cant get power when and where.? power is voltage.
do you have 12vdc at the pump cranking?
does car not start
why not post the symptoms so we can be on the same page.
why not?
i can walk you thru all fueling issues of any car.
why not post whats up;?
btw fueling is cut on all EFI if the EFI detects lost spark
so we check that 1st !
Fueling , EFI , is complex, (kinda) but is simple
the EFI dont fuel the engine, if there is no spark
or if it thinks you crashed, its a built in protection.
some cars inject and then stall in 2 seconds, due to , no spark.
the ECU monitors spark if it sees it drop dead, fuel ends.
even if spark is good. see why (answer, its a monitor)
the monitor works different on all EFI made.
fixed many.
Dec 10, 2013 | 1994 Toyota Pickup
2008 toyota hiace efi fuse affiliated with egr error
the sensor can be faulty, test it with VOM see the diagram attached from toyota
God bless you723f0c61-cb22-4f50-ae14-17f480160a6a.jpg5b2ea860-030d-4ae6-9a75-adfb1d28a808.jpg
Jul 20, 2013 | Cars & Trucks
How to change petrol fuel filter on toyota hiace 2007
On 2007 Toyota Hiace the petrol fuel filter is integrated in the fuel pump assembly placed inside fuel tank. It's not possible to change the petrol fuel filter without remove the fuel pump out from the tank. The petrol fuel filter is for fuel pump life.
Feb 02, 2011 | Toyota Pickup Cars & Trucks
Im trying to compare fuel consumption on a hiace 3ltr diesel turbo to a regius 2.8 ltr petrol
if both engines are in good condition, with the same driver, I would say that the diesel would have better mileage especially for highway travel. You may maximize this further if you utilize the turbo, meaning relying more on the turbo rather pressing the throttle.
Jan 18, 2010 | Toyota Passenger Cars & Trucks
Difficulties in starting my diesel hiace
Clem, you didn't say, but your car may have a fuel injection system, and in that case, this article speaks to the morning difficulty problem and the diagnosis:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Engine_System_Engine_Hard_To_Start_Morning_After_Hours.htm
If it is a carburetor, then here's the article for that morning problem:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Engine_System_Engine_With_Carburetor_Hard_To_Start_Morning_After_Hours.htm
Hope this helps! Brad
May 25, 2009 | 1986 Toyota Pickup 4WD
Retail Supplies Logo
353 people viewed this question
Top AIRBORNE FUELPUMPS & VALVES Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you an AIRBORNE FUELPUMPS & VALVES Retail Supply Expert? Answer questions, earn points and help others
