Question about Konica Minolta Magicolor 2530 DL Laser Printer
Ink I have replaced the pprinter with numerous cartidges. But everytime I print the ink smudges. You can run your finger across the paper and the ink comes right off. No matter color or just black. When I print a document that olny fills up half the page, it's like it mirrors what I just printed on the bottom part.
  • 186 Answers
There is a problem with your fuser assembly. It is not heating up enough to burn the ink onto the paper. This is usually replaced by a tech.
Posted on Sep 27, 2007
Replaced the ink in stylus sx 125 with genuine epson ink ... and now wont print at all
Perhaps try accessing the menu using the press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge carriage will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then pull out the ink by holding with thumb and first finger and rotating towards you. insert the ink again by pushing in and rotating away from you. close grey cover. now confirm ink replaced as per screen prompt. the machine will run the ink to the print head, takes a minute. then turn off and on and it 'should' work.
Jan 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My printer streaks ink across the paper when i print
just replace toner cartridge. I think the cartridge drum is broken
May 21, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Smudges on paper and ink is light when it does copy correctly.
It sounds like your drum unit needs to be replaced. Do the smudges look characteristically like a finger print? Technicians have a rule of thumb. Replace your drum, developer compound and general service the machine as often as you service your car. Assuming you do service your car as often as I do, it should be after every 25,000 copies. If the machine has never been serviced then its time you did.
May 25, 2009 | Sharp AR-5320 Black and White Copier
"check print cartridge was flashing, so I changed the ink, but it still is flashing. Also, there is an "E" across from the copies button. I disconnected it from the computer and "check print cartridge...
hi, is it hp ink cartridges? did you refill cartridge or replace?
press cancel button, then on/resume. if no change. make sure all tape, paper is removed from ink cartidge connectors and there is no dirt, smudges or adhesive or anything else that may interfere with the connection. reinstall cartridges. if still no change, power off, then disconnect power. wait about 5 mins. reconnect and power on. this should reset the printer.
Apr 24, 2009 | HP PSC 1315 All-In-One InkJet Printer
Brother MFC 7820N Smudging Concern
If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Oct 30, 2008 | HP LaserJet 4250n Printer
Cannot get a good copy of a fax
Use ony GENUINE HP ink cartidges.
Look inside to make sure there are no scraps of paper that the paper is scraping against on the way out.
Mar 12, 2008 | HP 1040 Plain Paper Inkjet Fax
R220 colour errors
chech the ink pan below maximum waste overflow, take the injection pump it or enject until ink finish.check ink cartidge or not fully engage the lock.
Nov 15, 2007 | Epson Stylus Photo R220 InkJet Printer
Cannon Imageclass printing problem
You need to check your glass first to make sure it has no scratches. Then you can run a copy and open door to stop paper in the center of the machine, b4 it goes through fuser. If line is on copy, you have a bad drum. If not your upper fuser roller is bad.
Oct 19, 2007 | Office Equipment & Supplies
Laser Printer
When the paper is fresh out of the printer, does the ink that looks okay smudge if you rub it with your finger? If so, it means the fuser is going bad. Otherwise, it's probably a bad toner cartridge that's leaking toner onto the paper.
Jun 12, 2006 | HP LaserJet 2100 Printer
Konica Minolta Magicolor 2530 DL Laser Printer Logo
197 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
