My Simpson eziloader 7kg washing machine won't start, there's 3 clicks and end light flashes 4 times, replaced the door catch mechanism but to no avail.
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: Simpson Eziloader frontload washer clunks 3 times and ends
The motor controller or ECU is to blame.
Have them checked & replace as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: Simpson Front Loader won't start - Clicking Noise
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 15, 2010
Daniel S
  • 4323 Answers
SOURCE: We have a simpson eziloader
Hi
I believe it either the motor or the timer/control board issue. The click sound that you hear can be when the timer is trying to work but is unable to, so the timer motor should be replaced. If you hear the click sound from the bottom of the unit then it is the motor that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 11, 2011
  • 3 Answers
SOURCE: simpson eziloader 5.5kg washing machine When
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Posted on Jan 23, 2011
My simpson eziloader machine won't start - when I press the start button it clunks a couple of times then nothing - water won't enter have checked the inlet pipes
sounds like blocked pump or door latch sensor/switch more likely pump blocked.thats normally first to activate in wash cycle.if unsure seek help to locate and check.it ll be either accessable from bottom front of machine or you may need to tip it up as it ll be at bottom of machine.unplug first,and if you pull pipes off pump to access there will be some water.hold waste pipe as low as itll go to release any water left in machine
Feb 21, 2015 | Simpson Washing Machines
Simpson eziloader 7kg won't drain water?
check the pump hasn't got something stuck in it
Sep 10, 2013 | Washing Machines
I need a user manual for my 7kg EZIloader front loading Simpson washing machine
Google the make and model and add the words user manual to the end. There you will see numerous sites that offer either free or inexpensive user manuals that you can order or download. My favorite site is simply manuals.com.
Sep 04, 2011 | Washing Machines
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
Jan 11, 2011 | Washing Machines
Simpson ezi loader 5.5kg front loader. when it goes to start the door clicks 3 times then the end light flashes. I am an electrician. but I do not work on appliances. if you could send me a...
the door is clicking because it is trying to lock the door but is unable to for some reason what is the make/ model number of the machine? most likely it would be something dealing with the door look but id rather be 100 percent correct then assuming Please send model number i await your reply Thanks again
Rick
Dec 09, 2010 | Washing Machines
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution...
Good luck.
Apr 27, 2010 | Zanussi FS1455W Front Load Washer
Sep 03, 2009 | Washing Machines
Jan 14, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
