Question about Dell Computers & Internet
Reset x600 I installed the following graphics card in to my Dell Optiplex 620 desk top after connecting the computer back together i was given the following error "READON X600 SE P/N 620 113-a26044-108 BIOS". I was unsuccessful in booting up the computer. after doing some research online i read that it is possible to reset the computer for the graphics card. does anyone know how to do this or make this work?
2 Suggested Answers
  • 166 Answers
SOURCE: Existing Radeon X600 card in Dell Optiplex gx620.
Check for motherboard or powersupply issues. The GX620's were in a range of DELL models that were affected by bad capacitors.
Failure of motherboards and power supplies is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies (not just DELL) and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Make sure you look at the ones under the fan shroud (back of processor). The dead giveaway is the fact that you are getting the same thing after you switched video cards. If you listen to your computer as it starts up, a few of the devices may not start (hard drive, etc). A failed video card will usually give you the "No signal message", but the computer should sound normal when starting up. Mobos are usually expensive to replace because the computer makers have them made especially for them and only order so many. They usually do not have a lot of extras laying around. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and this could cause your problem. Let us know what you find out.
Posted on May 01, 2009
The screen has turned green on my dell 3043 all in one desk top
Try doing the following troubleshooting to see if the issue is resolved.
  • Replace the connection cable, i.e., VGA, DVI, etc.
  • Ensure the graphic card's connections are not loose.
  • Update graphics card driver.
Typically this occurs when one of the above happens, but if none of the above solutions work your graphics card (integrated or dedicated) may need to be replaced.
Jul 18, 2016 | Dell Inspiron 3043 19.5" Touch All-In-One...
Dell optiplex 620 open but no display , monitor work by other pc
Could be your Graphics card, I would try installing a PCI VGA or DVI card. HDMI would be excellent as well. what type of inputs are in the OP 620 this is an older PC and may have PCI other PCI cars installed.
Dec 14, 2013 | Dell Computers & Internet
I installed the following graphics card in to my Dell Optiplex 620 desk top after connecting the computer back together i was given the following error "READON X600 SE P/N 620 113-a26044-108 BIOS". I was...
Enter the bios by pressing F2 during the first seconds of the boot. Then look for "restore to factory settings".
If that doesn't work the look for the graphic/monitor settings and try to change settings.
Good luck and let me know how it goes
Oct 18, 2013 | Dell Computers & Internet
I want to know if i can install a siig firewire PCIe card into a dell optiplex 620 all-n-one computer
Hi Carl,
I am guessing you are asking about the Dell Optiplex "GX"620. :-) Anyway, if you are using the all-in-one setup shown in this picture:
then unfortunately, with the small form factor case that is used with this particular version of the Optiplex GX620, the motherboard doesn't have any expansion ports to be able to install a PCIe card. Here is a picture of the small form factor case with the side panel off of it so you can see how little room is left in the case after all of the components are installed.
As I am not familiar with what you are trying to accomplish or why you need a firewire card installed, I can only make a small suggestion, such as looking for a firewire to USB adapter for whatever you are trying to connect to your computer. If you are able to expand on what you are trying to accomplish, or what kinds of problems you are having, I would happy to try to lend you my expertise. :-) I hope this helps.
-Nathan
Sep 26, 2013 | Dell Computers & Internet
I need vga driver for dell optiplex 380
Which specific model is the Optiplex 380 and what OS is installed on the computer? Does your computer have a graphics card installed or are you using the on-motherboard graphics?
Most of the Optiplex drivers are available here: http://www.dell.com/support/drivers/us/en/04/Product/optiplex-380 . Use the drop down menu to select your OS. Expand the section labeled video for the Dell drivers. If you are using the on-board graphics, use the Intel Graphics driver. Otherwise, you need the one for the manufacturer of your video card. Note: Dell has the drivers for the NVidia and AMD cards that were installed on some models. If you have upgraded or added a new card, get the drivers from the manufacturer.
I hope this helps.
Sep 28, 2012 | Computers & Internet
Non display for DELL GX 110PC Desktop
Either your monitor is bad or the video card inside the computer is bad. To isolate the problem try a different monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker. If the borrowed monitor works, then your original monitor is bad. If the Borrowed monitor does not work, then the video card inside your computer is bad.
May 11, 2012 | Dell OptiPlex GX110 PC Desktop
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
Aug 07, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
Existing Radeon X600 card in Dell Optiplex gx620. All of a sudden in displays a black screen and just shows the graphic card info at the top. Won't boot. Just hangs there. Unistalled this card, put in a...
May 01, 2009 | ATI RADEON X600 SE 128MB DDR1 PCI Express...
Lost resolution windows vista upgrade on GX260
Hi all,
I tried numerous solutions for this issue and none of them worked except this one. I tested it with Vista Ultimate and don’t know if other Vista versions have the same drivers but here’s what worked for me:
1. Right click ‘Computer’ then left click ‘Properties’ to open up System window.
2. Click ‘Device Manager’
3. Click ‘+’ on ‘Display Adapters’ and you should see the drivers for your video. Right click and select ‘Update Driver Software...’
4. Select ‘Browse my computer for driver software’ and click ‘next’.
5. Click ‘Let me pick from a list of device drivers on my computer’
6. Untick ‘Show compatible hardware’
7. Select ‘Intel Corporation’ then select ‘Intel 82865G’. Click next.
This will install the drivers. No they are not the same drivers for the hardware but they work a treat!
May 05, 2008 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
Alun Cox
