Question about Panasonic AG-DVC200 DV Digital Camcorder
Parts My problem is mechanical .what i'm looking for is the metal piece that is attached to the front of the camera to on witchthe the view -finder is slid into and then tighted in place.Names of places where i might find such a part will be much apriciatted. Thanks Fazz
    Champion:
  • 221 Answers
P/n is VYQ1529. Panasonic lists this as discontinued.
Posted on Oct 19, 2007
I have an old canon ftb and when looking thru view finder there is a red rectangle almost like a piece of tape stuck on bottom right corner. thanks for any help. See attached
Hi Dear!
http://www.baytan.org/prak/pdf/CanonFTb.pdf
Please check with page 21 on the manual. However, it looks like a loosen piece from penta prism supporting piece moves around. It won't give shutter functionality but it could cause metering problem sometime. It has some timing involve with disassemble, I won't recommend you to opening the camera unless you are ok with lose your camera broken. You should bring to your local repair shop.
Hope You Luck! A Professional Camera Clinic Guy!
Apr 07, 2015 | Canon Cameras
Cracked view finder
That would depend on which part of the viewfinder that needs repair or replacement. If it's the piece of glass at the very back, where you put your eye, it wouldn't be that expensive. If it's the prism inside the hump atop the camera then it would be quite expensive.
May 27, 2013 | Pentax K20D Digital Camera
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
Is it bad to keep the lenses attached to your film cameras when storing them for 7 to 8 years in the camera bags thanks Also my Minolta maxxum 500si's view finder is not bright outside in the bright...
it's just okay to store with the lens on the camera, but it's better to have a camera body cap and front and back lens covers on the lenses with cases stored in a dry place with batteries removed from camera.
for the finder i would suggest a soft rubber eye piece accessory that fits on the finder.
Sep 13, 2009 | Minolta Maxxum 500si 35mm SLR Camera
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
I see a circle when thru view finder
Sounds like the Focusing screen in the camera is missing. (its the frosted piece of glass that is above the mirror)
Sep 28, 2008 | Canon EOS-5D 12.8 Megapixel SLR Digital...
View finder in samsung VP- W90 very blurred. Focus not the problem.
If the focus is blurred on the view finder, assuming you are talking about the eye piece and not the lcd, then it is a out of focus issue. Even though when you view it it's ok. Some cameras still have a focus knob somewhere to focus the eye piece.
May 27, 2008 | Samsung Cameras
My Minolta Maxxum 3Xi has a dark picture in the view finder. It won't focus on anything because everything in the view finder is dark, if not completely black. I was told it might be the aperture ring. ...
The aperture ring is the right diagnosis. The aperture mechanism has a broken piece that can be repaired by a competent repair shop for under $75. There are no parts available for Konica Minolta cameras since Sony bought them - the part can be rebuilt.
Oct 22, 2006 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Panasonic AG-DVC200 DV Digital Camcorder Logo
76 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
