Fujiaire air e8 - Heating & Cooling
Fujiaire air con operation green light blinking
Most likely logic fault - shut power 100% off at breaker box for 5 minute and turn back on.
Nov 06, 2016 | Heating & Cooling
Error code E8 always appear then the aircon automatically shut down
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. I can help if you provide this information.
Air Bulance AC Cleaning Repair Services
Apr 20, 2015 | Heating & Cooling
Once putting off fujiaire split ac its shows E3 Error
Try this: http://www.manualslib.com/
I Googled this: Fuji air conditioner E3 Error
One item seems to have the answer:
http://errorcodeairconditioning.blogspot.com/2010/10/fujitsu-air-conditioner-error-codes.html
"E3:00 Return air thermistor short circuit"
So more than likely you have a crossed wire issue. good luck.
I'd call ACND service man!
Mar 05, 2015 | Heating & Cooling
Received u8 alarm display,aircond type fujiaire
Here's a link to fujiaire's contact page: http://www.fujiaire.com.my/contact.html
I'm sure they'll be able to tell you; or else contact your dealer- installer
Jul 11, 2014 | Cars & Trucks
Fault code f6 fujiaire model fbsv2452rk,
HI ALL, HERE JUST WANT TO ASK ABOUT ERROR E3?
Apr 22, 2013 | Heating & Cooling
Error e8
I don't see a error code E8 listed.. I take it your tried unplugging unit for at least 30 minutes then reconnecting unit. Could be a bad controller or display. If unit hasn't been serviced in a long time.. it should be checked for proper coolant levels and leaks.
You can find the service manual here...
files.totalhomesupply.com/data/LG/PTAC/LP123CD3Aservice.pdf
Nov 16, 2011 | LG LP123CD3A Air Conditioner
I have a Fujiaire split unit( wall type). The problem i have now is when i run the unit, it show a thick icing on the discharge side till to the indoor unit and also the air coming out from the unot os not...
System has lost some of the refrigerant charge. This means the system has a refrigerant leak.
Have a reputable heating and air contraxctor find and repair the leak, recharge the system and it should run perfectly.
Sep 04, 2011 | Fujitsu Heating & Cooling
My air conditioner is say e8 how do I get it to work?
the e8 code has something to do with getting the control board wet. When u try to operate it with the controls on the unit nothing happens. But u can still use the remote to turn it on and adjust the fan and cooling settings. It may have collected some moisture or condensation or if you wer cleaning it it got wet. It should all work again once it dries out.
Jul 22, 2011 | Haier Energy Star ESA3183 Air Conditioner
Split unit aicon fujiaire appear e3 message
I have a Fujiaire split unit(wall type). I have this problem quite frequently, an error code E04 display, Try to look at the operating manual, it does not specify the problem, I check the compressor motor winding, the amount of F22 charge and clean the outdoor and indoor unit. Wonder why put an Error code when there is nothing on the troubleshooting list. But whenever the authorize repair man come for servicing, he could not tell me. Does anyone has a solution?????
May 26, 2011 | Heating & Cooling
Blue ice air conditioning unit (portable) not heating erro message E8
Every co. has their own logic control and error codes , however in my knowledge it may be of :
1. motor connection
2. Defrost sensor error-chk condensor/ evap. coil
provide some more clue to explore option of trip.
Jan 03, 2008 | Heating & Cooling
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
