Question about Asrock Motherboard K7S41GX for AMD Sempron/Athlon/Duron (B01029)
Shutting down the computer shuts down only after two minutes after it has been opened. i have to remove the power cable and put it back again then still same problem occurs. is there a problem with the system board?
    Problem Solver:
  • 6 Answers
Try to reset the bios using the jumper provided for cmos. start ur pc with out battery. try it
Posted on Nov 29, 2007
    Novelist:
    Scholar:
  • 167 Answers
Yes mostly this is the case that your system board is faulty. You should get your motherboard serviced. If it is still under warranty you may get it replaced.
Posted on Sep 27, 2007
SOURCE:
Computer shuts off after 2 mins when case side panel is on
Might be faulty PSU power supply unit
it sounds like a loose connection of some type check the power button connections make sure the soldered wire connections are good and dust free
check cmos battery seating some motherboards cmos batteries are soldered in
it could be a loose or faulty power or data lead check these from motherboard to hard drive also make sure the CPU cental processing unit has a secure dust free seating an has thermal paste
it does sound odd
hope this helps
Jul 04, 2012 | Computers & Internet
My desktop keeps shutting down for no reason. I just recently went to the repair shop for a tech to look at because of the automatic shutting down and all he did was clean out my system i lost all my files...
check for the switch when you power on the computer if it stuck while pressing it, if so put some small amount of oil in the corner of that switch, if the switch has no problem when you press it open the computer make sure its not plug in then remove the heatsink that has a big fan and four lock on its side using a screwdriver remove the dried thermal paste replace it with new thermal paste you can purchase it from any computer store then make sure that you put a small amount only half the size of the peanut then put back the heatsink again screw to lock in place make sure not to over lock it
Aug 07, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
My Sony Laptop is stuck, not reboot nor shutdown,
Hey there, when your computer completely freezes while still being on you simply have to remove the power cable and pull out the battery. Then put the battery and/or power cable back in. When you start up your computer again it will say your computer wasn't shut down properly, simply select "start windows normally" and everything should be fine again.
Jul 27, 2011 | Computers & Internet
I have just purchased a Belkin Basic Wireless Modem Router. I tried installing it but when doing so it tells me to check that the cables are connected. I have done this but it still won't install. Is...
After you have installed the unit shut everything down. By shut it down I mean remove all power. This includes the computer. leave all power removed from unit(s) 1 minute. When powering back up power up cable modem first if you have one. Wait for unit to completely boot up. Next power up the wireles router. Once again wait for it to boot completely. Lastly boot your computer. Hope this helps.
Dec 23, 2010 | Belkin Basic Wireless Router
My aspire 5100 turns on and shuts right back down
Hi
disconnect the power cable and remove the battery and then press nad hold the power button for a minute. then connect every thing back and then see if the screen comes on.
in case it does not then again remove the battery and power cable and remove the hard drive and ram and put it back in again.
and then check still does not work see if the screen comes on an external moniter, still if it does not come on call ACER if it is under warrnty they would give you free repair.
May 03, 2010 | Acer Aspire 5100 Notebook
What do we do when Canon MX330 code comes up besides shutting off the printer and putting it back on?
Turn off your computer and completely shut down.
Turn off your printer.
Disconnect all cables and electrical cords from your printer.
Make sure the electrical cord is also removed from the wall.
Wait 5 minutes and reconnect the power cord to the printer.
Then connect the printer cable from the computer to the printer.
Turn on your printer
Now reboot your computer (cold boot)
Your printer should now clear itself.
Mar 23, 2010 | Canon PIXMA MX330 Multifunction InkJet...
When i plug my dvd writer to the power supply it keeps causing my computer to shut down and start back up then shut down again
It has gone faulty and is causing a power overload and this causes the PC to shut down, so it will not be damaged. Either the power supply Inside the DVD is faulty or the DVD, is.
Feb 27, 2010 | E-Machines eMachines Desktop PC
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
I took my gateway gt5620 in because it would shut down by itself. It would restart. They took the graphics card out and it worked for a while. Now it is doing the shut down again. I took the side panel off...
Sounds like an overheating problem. May want to remove the processor and check the heat sink material. While you have it out you can clean the fan and the heat sink. Make sure your air flow isnt blocked in any way and neaten up the cables if necessary. You could also consider adding another fan.
Oct 01, 2009 | Gateway GM5620 PC Desktop
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Open Questions:
See all Asrock Motherboard K7S41GX for AMD Questions
Asrock Motherboard K7S41GX for AMD Sempron/Athlon/Duron (B01029) Logo
65 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
