Question about Task Force 2000 PSI Electric Pressure Washer NEW 6127
I bought one and it worked fine until just recently. I haven't used it more than five or six hours though. After using it recently when I turned it off it was fine. Early in the week I was going to use it. I plugged it up, connected the water, turned the water on, then turned the machine on, nothing happened. I went over everything the manual suggested, still nothing. Tell me what to do.
I have the Wireless Racing Wheel with Force Feedback. We usually play Forza Motorsport 2 and everything worked fine. We recently bought Need for Speed Hot Pursuit (2010) and the pedals don't work. ...
Hello, NFS Hot pursuit 2010 on the Xbox 360 officially supports the Microsoft wheel but any Xbox 360 wheel will most likely work fine....their words. I haven't played the console version but if you say the wheel works I suggest you try remapping the pedal controls under gameplay settings if this is possible
I hope this helps, thanks for using FixYa.
Sep 02, 2011 | Microsoft Wireless Racing Wheel for Xbox...
Have a 1996 318i BMW and cannot find how to change clock setting. The manual is in Japanese!
  • Turn the car on then hold the "Clock" button until the ":" begins blinking -- usually four to six seconds though some take up to a minute.
  • Use the "1" and "10" buttons to set the minutes, "100" and "1000" buttons to set the hour.
  • Press the "Set/Reset" button to set the new time.
  • send me 4 thumbs up
    Jan 23, 2011 | Computers & Internet
    My computer was working fine, but I lost my charger. I bought a universal charger and used it for some time. One day I plugged the computer in and the light on universal charger lit up until I plugged it...
    I think that your battery is soooo flat it may be no good, take battery out, THEN connect the Correct adapter, and see if that works, if it does, then ya do need a new Batt, or perhaps a good long10-12 hour charge first, with NO use at all during that period.
    Jan 26, 2010 | Toshiba Satellite M45X-S331 Notebook
    PRINTER REFUSES TO PRINT YELLOW
    Derrick, Came across something the other day and thought of you even though we know that there are a lot of yellow tanks with bad chips in them.
    Lift the ink tank carriage body up and expose the print head, there is a lever to lift up and pull out the print head. Now soak that print head in ammonia for several hours and then rinse it out with a warm water jet, using a water wand or just the faucet head. The print head has a rather large hole with a screen to accept the ink from the tank. You can wipe it off and blow it out using your mouth too, just don't **** on it. Canned air is the way to go and blow the canned air on the bottom too and then wipe the print head forward and to the right on a paper towel damp with rubbing alcohol. Do this until you are getting some yellow color easily. Then reinsert the yellow print head.
    Now, put everything back and latch it down. Unplug the printer pulling the cord from the back. Hold the OK and Cancel/reset button down at the same time and reinsert the power cord. Hodl these buttons down for about six seconds until the lights blink or you get a message and then release. Now press and hold the On button down for five seconds. Now, turn the printer off and wait until its finished. Unplug the cord from the back and leave it out for 20 minutes, then reattach the power cord and turn the printer on and print a test page using the menu. See if your yellow is okay now.
    Regards,
    Worldvet
    Jan 14, 2009 | Canon Pixma iP4500 InkJet Printer
    Frigidaire built stacked washer and dryer
    There is a thermal cut off on the motor. when it overheats it will trip and not start until the motor cools down. Replace the motor to solve the problem.
    Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
    Task Force 2000 PSI Electric Pressure Washer NEW 6127 Logo
    27 people viewed this question
    Top Task Force Garden Experts
    Tom Chichester
    Bill Boyd
    Are you a Task Force Garden Expert? Answer questions, earn points and help others
