Question about Canon PIXMA Office Equipment & Supplies
MG5300, duplex printing in booklet mode, short-side stapling, 2 pages/side, landscape orientation. The instructions said that the booklet mode was designed to fold in the center between pages. This would necessitate that the text should be oriented in the same direction on both sides of a sheet. Instead, the reverse side printed upside down, so I can't fold the sheets and staple in between the pages. I have to bind on the left (long) side and view the pages from the right long side, unfolded. I saw no option to specify text orientation on reverse side of sheet. How can I make a 4 page/sheet, center-bound booklet? Or is it not a booklet?
3 Suggested Answers
SOURCE: Canon MP610 Printer When automatic duplex
I haven't found a way to do this using the printer settings.
There is no (apparent) simple solution, but needing tp print a 56 page pdf form the only solution was to load the pdf into Adobe Acrobat and then in the 'document' pull down menu select 'rotate pages', then select '180 degrees' and also 'rotate even pages only'. This then prints OK.
The down side is that you need full Adobe Acrobat rather than just the reader.
I have been unable to rotate pages through 180 degrees in MS Word but it is possible using MS Publisher.
Misterfish
Posted on Feb 11, 2009
  • 114 Answers
SOURCE: Making a booklet out of a multi-page PageMaker file
many questions, the answer should be yes and all is in the driver settings but it all depends on if you have the correct driver installed and configured correctly for your copier and if your finisher is a booklet finisher. if you have every thing laid out in page maker correctly and the driver is setup correctly then it should do just fine.
Posted on Apr 18, 2010
Can I print on both sides of the page
Here are the instructions for duplex printing.
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
1. Open the printer driver setup window, and check the Duplex Printing check box on the Page Setup tab.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note
sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper or Photo Paper Plus Double Sided is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
You can download a users manual for your MX310 at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Please rate this solution. Thanks.
Sep 27, 2011 | Canon PIXMA MX310 All-In-One Printer
How to get a Canon MG5220 printer to print 2-sided copies
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
Feb 05, 2011 | Canon imageCLASS MF7480 Laser Printer
Can the canon pixma 860 print a sheet of paper in duplex mode
Hello !
Your printer prints 2-sided and you can change the orientation of output from portrait to landscape.
Hope this helps.
Oct 04, 2009 | Canon Office Equipment & Supplies
I am having trouble with booklet style printing -- under Vista
After a great deal of frustration and trying every permutation possible I succeeded amid an ever rising mountain of paper! . . .and find that I have to totally ignore the "Booklet printing" option . . . but ask it to print landscape; 1 page per sheet; flip on short edge.
Now I need to do the same to crack the sytem for the Cannon Pixma IP4000 inkjet.
Thank you for your consideration.
Sep 30, 2009 | Brother HL 5150D Laser Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
5. Click OK.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
When I duplex in landscape mode the text points indiferent directions. How can I change this? For example - one side is upside down.
In page setup, in the Duplex section, check Duplex and Automatic, and then select Short-side stapling (Right). I had the same problem, and this solution worked for me.
Jul 11, 2009 | Canon PIXMA MX850 Multifunction Printer
Booklet printing word on ir5000
WHEN YOU GO TO THEPRINT PREFERENCES CHECK THE ORIENTATION OF THE DUPLEX IT WILL HAVE LONG END BIND OR SHORT MAKE SURE IT IS SET FOR LONG END THIS SHOULD MAKE THE ORIENTATION RIGHT OTHERWISE IT WILL TRY TO PRINT AS A CALENDER WILL COME OUT IE LIFT UP THE PAGE TO SEE THE NEXT IMAGE
Jul 03, 2009 | Canon imageRUNNER 5000 Copier
I am working with a Ricoh Aficio 3260 machine. I have been sent a 20-page Publisher document laid out in Landscape, each page is set up as 8.5 x 5.5. I want the Ricoh to produce a booklet stapled...
Well, I don't have a document in that format exactly to play with, but assuming you are using the PCL 5c driver, it should be a fairly simple task. If your using another driver (ie: RPCS) then it will be similar, just a little different looking dialog box.
Open your document, Select "Print", select "properties", you can change the "orientation", and "layout" (pages per sheet), 'duplex', and staple (assuming you have a booklet finisher installed and configured in your printer properties). There is an icon in the left corner that changes with the settings and should help you with the them. Obviously, you should only print 1 set, or even just a page or 2 to check the output. These types of things are always a bit of trial and error until you have done it a couple times. I hope this helps
Mar 06, 2009 | Ricoh Office Equipment & Supplies
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
How do I print on both sides of my paper
On printers without a duplexer (a device that flips the paper to allow printing on both sides) you will have to print the first side, manually flip and print the second side. If you're using MS Word or MS Publisher you can easily configure the program to organize the pages for you: Start a new, blank document. -Click File, Page Setup then click the Margins tab. -In the Multiple pages section select Book fold. -Set your document to landscape orientation if it is not already. -In the Inside and Outside boxes, type or select the amount of space you want for your margins. -In the Sheets per booklet list select the number of pages you want to include in a single booklet. If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets. -When you get ready to print make sure you check the manual duplex box (should be in the first dialog box that appears when you click on File, Print). Word will print the first page, and then prompt you to take the pages that just printed and load them into the input tray of your printer. The trick is to learn how to orient the pages correctly for your printer. Good luck.
Jun 17, 2007 | HP DeskJet 1600C InkJet Printer
49 people viewed this question
old marine
old marine
