Question about D-Spec Adjustable Shocks/Struts Subaru WRX 02-07 DSP-10
TOKICO AIR RIDE SUSPENSION LEVELING COMPRESSOR PUMP NEED SCHEMATIC FOR WIRING IT TO ANOTHER VEHICLE
Air ride suspention won'twork
If the car is riding lower than usual, making abnormal sounds, and its compressor won't start, it indicates the replacement of air suspension compressor.Accordingly, if the compressor has failed, there is usually an air leak somewhere in the air ride suspension that needs to be found and fixed before a new compressor is installed.
The air compressor is what provides the air suspension system with compressed air required for it to function. If you suspect that there is a problem, you should have proper vehicle suspension inspection by a professional technicians such as Eurobahn BMW MINI Mercedes-Benz Audi. They can determine if the vehicle needs an air suspension compressor replacement or repair.
Aug 09, 2017 | Cars & Trucks
I have a 2006 lincoln navgator why in the front does it keep going down
The Navigator has an air ride (air bag) suspension system. It uses a compressor and air bags in the suspension to provide a smooth and level ride. These systems are fairly reliable, but can malfunction due to misuse or parts failure. A common problem with these is that you must turn off the air ride system before raising the vehicle on jacks or a lift. This is because the weight of the vehicle provides a feedback pressure to the compressor to allow it to determine proper level and shutoff point. If the vehicle's weight is removed from the suspension with the air ride on, the compressor can over-inflate the air bags and cause them to blow out and fail. Other things that can happen are leaking air hoses, o-rings, seals and such.
Nov 26, 2016 | Lincoln Cars & Trucks
Where is the ride control located on 2000 lincoln continental
Dual Action System
The suspension system incorporates a rear load leveling system that maintains the vehicle at the proper ride height under varying conditions of vehicle load, and an optional road calibrated suspension ride control system that varies the damping of the shock absorbers between soft and firm.
The rear load leveling system uses air springs to support the vehicle weight. The quantity of air in the rear air spring is controlled by the Vehicle Dynamic Module (VDM) to maintain a predetermined vehicle ride height. Each air spring has an air spring solenoid to control air flow into and out of each air spring.
The optional ride control system uses four shocks with electronically controlled actuators. The shock actuators are internally mounted on the lower bodies of the front spring and shock assemblies and the rear shocks. The action of the shock actuators is controlled by the VDM. The VDM sends a signal to an appropriate shock actuator which switches to either soft or firm damping. Normally the shock actuator setting is in a soft, luxury car mode. This is done by causing an electric current flow through the actuator, which induces electromagnetic force that moves the shock actuator from a firm to a soft position. When driving situations require, the setting is switched to a firm, high performance control mode. This is done by removing power to the actuator, allowing the shock actuator to return to he firm mode.
The shock actuators are not replaced separately. If testing indicates an actuator failure, the entire shock absorber must be replaced.
A microprocessor controls the air suspension and ride control systems. The microprocessor and its support hardware are contained in the Vehicle Dynamic Module (VDM) . It responds to signals from various sensors in the vehicle to maintain the desired ride height while the vehicle is either moving or stopped. It accomplishes this by opening and closing solenoid valves. It also turns on the compressor through the compressor relay or opens the vent solenoid in response to signal inputs from the air suspension height sensor. It also controls the shock actuators, if equipped.
Normally, the VDM uses a 45-second averaging interval to determine when fill and vent operations are needed. However, door switch signals' inputs can override the 45-second averaging interval so fill and vent operations can begin immediately, if needed.
Air Suspension Service Switch
The air suspension service switch provides the system enable signal to the vehicle dynamic module in the ON position only.
Air Compressor
The compressor contains a thermal overload circuit breaker. The circuit breaker automatically resets after a cool down period and after being tripped by excessive compressor motor heat.
The air compressor assembly consists of the compressor pump, electric motor, and vent solenoid (must be installed as an assembly).
Air Suspension Height Sensor
The air suspension height sensor provides a continuous voltage signal corresponding to vehicle ride height. For instance, when the sensor is fully compressed, the voltage signal sent to the Vehicle Dynamic Module (VDM) is 4.5 volts. When the sensor is fully extended, the voltage signal to the VDM is 0.5 volt.
Each one of the air suspension height sensors measures the actual difference between known reference points so that the VDM can respond to variations in ride height.
If the wheel speed and travel are above a predetermined level, the shock actuators are switched to the firm position. This reduces the chance of grounding out the suspension when traveling over rough road surfaces.
Body roll during extended, high lateral-force turns (freeway exits) are also neutralized to prevent unwanted leveling actions at these times.
Air Spring Solenoid Valve
Never rotate an air spring solenoid valve to the release slot in the end cap fitting until all pressurized air has escaped from the spring to prevent damage or injury.
The air spring solenoid allows air to enter and exit the air spring during leveling corrections. The air spring solenoid valve is electrically operated and controlled by the VDM.
Vent Solenoid
The vent solenoid allows air to escape from the system during venting corrections. The vent solenoid is located in the air compressor cylinder head and shares a common electrical connector with the motor. The vent solenoid is enclosed in the cylinder head casting, which forms an integral vent solenoid housing that allows the vent solenoid tip to enter the pressurized side of the system. Air leakage past the vent solenoid tip is prevented by an O-ring seal.
When it is determined that a corner of the vehicle is high, the vent solenoid opens to provide an escape route for the pressurized air. The vehicle will not lower unless the air spring solenoid is also opened to allow air to leave the springs.
May 25, 2014 | Televison & Video
Can not get the new air ride compressor to come on
Make sure the trunk switch is turned on. Your doorjam and trunk switches are wired into the Air-ride. They must sense the openings are closed before the lift compressor will work.
There are level controls for height. If the car was put on a lift without the switch being turned off, the positioner may be stretched beyond working.
Feb 27, 2014 | 1997 Lincoln Continental
2007 Yukon Denali XL autoride suspension light comes on intermittently
Would need to know what DTC'S - diagnostic trouble codes are stored in the module for the autoride suspension . Hooking up a professional type scan tool ,looking at input data to the module etc... Looking at a wiring diagram an testing electrical circuit's using a DMM - digital multi-meter . Reading how the system works ,what all involved in making the system work . This is how a professional Tech would go about diagnosing this .
The automatic level control (ALC) system maintains a desired rear suspension position under all types of towing, hauling and loading conditions. The following components are involved in the operation of the ALC system:
• Air line tubing--Pressurized air from the ALC compressor is pumped to each of the rear shocks via air line tubing.
• Air drier--Pressurized air from the compressor is run through a drier containing a moisture absorbing chemical preventing water accumulation in the rear shocks.
• Compressor--Supplies pressurized air to the rear shocks
• Compressor motor relay--The relay supplies battery positive voltage to the ALC compressor motor.
• Pressure sensor--The electronic suspension control module (ESCM) module provides a 5-volt reference and low reference to the ALC pressure sensor. The module receives the signal voltage that is relative to the air pressure applied to the rear shocks.
• ESCM--Controls the ALC system and electronic suspension control (ESC) system and detects failures in both. The module monitors inputs from the position sensors, and pressure sensor to determine when to raise and lower the vehicle to trim height as the vehicle is loaded or unloaded. The module limits pump activation to 255 seconds to prevent thermal damage.
• Exhaust valve--An electric solenoid activated by the ESCM to vent air pressure from the rear shocks.
• Left and right rear suspension position sensors--The module provides a 5-volt reference and low reference to all 4 of the body-to-wheel suspension position sensors. The sensors send the ESCM a signal voltage that is relative to the rear suspension ride height
• Left and right rear shock absorbers with internal air chambers and dampers--Dampens the rear suspension and maintains trim height depending on the air pressure applied.
Nov 04, 2017 | 2007 GMC Yukon XL Denali
2003 Yukon Denali has Service ride Control Warning..wat to do?
Hi Jose:
The first place to start is to have Ride Control Module scanned for trouble codes, this requires a high end scan tool. Most common problem is the air compressor in the rear or a height sensor. Here is how the system works.
Automatic Level Control Description and Operation
The RTD system is bi-state real time damping system. The Suspension Control module controls the suspension damper solenoids and suspension position sensors, along with parts of the automatic level control (ALC) system and electronic variable orifice (EVO) power steering system.
The Automatic Level Control system consists of the following:
• Suspension Control Module
• Compressor/Leveling Module
- Air Pressure Sensor
- Exhaust Solenoid
• Compressor Motor Relay
The objective of the Automatic Level Control System is to provide constant ride height at all load conditions. The Suspension Control module monitors body-to-wheel height, and vehicle speed.
The Suspension Control module will use the rear body-to-wheel displacements and vehicle speed inputs to keep the rear trim height of the vehicle at its desired level.
The electronic suspension control (ESC) system is bi-state real time damping system. The ESC module controls the suspension damper solenoids and suspension position sensors, along with parts of the automatic level control (ALC) system, if 1500 series.
The ESC system consists of the following:
• The ESC module
• The compressor/leveling module, if 1500 series
- The air pressure sensor, if 1500 series
- The exhaust solenoid, if 1500 series
• The compressor motor relay, if 1500 series
• The steering handwheel speed/position sensor
• The suspension damper solenoids
• The suspension position sensors
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 16, 2011 | 2003 GMC Yukon Denali
Warning suspension workshop message appears in center display ride heigth cannot be reached. . passenger front suspension does'nt lift.
Hi!
Your vehicle is equiped with a small compressor that pumps air into either a bag or shock absorber, each one has a leveling mechanism that sends the signal to pump more air to that particular side. This keeps your vehicle leveled at all times, like when you have passangers in the back sit, passenger sit, or luggage.
The message you are getting means that either the air is not getting to the front passenger suspension to level it up, which could be due to an air leak, or the bag or the part of the suspension that lifts that part of the vehicle is defective.
You can get a diagnostic at any reputable suspension shop at no charge to find out the exact cause.
Good Luck!! Don't forget to rate this post!!
Sep 07, 2010 | 2006 Bentley Continental
The rear suspension air bags no work
start here
The air suspension system is designed to improve ride, handling and general vehicle performance for static, on-road and off-road driving condition:
  • Ride is improved by using an air type spring (the soft ride is inherent).
  • Handling is improved by maintaining constant vehicle attitude.
The system consists of unique rear air springs, air compressor, air lines, air spring solenoids, height sensor, air suspension control module, attachments and associated signals derived from both driver and road inputs. With these components and signals, the air suspension control module commands changes in vehicle height that are necessary for the load leveling features.
The load leveling feature rear air suspension (RAS) systems shall automatically make adjustments in vehicle height so that the vehicle is always at trim height and constant front-to-rear vehicle attitudes are maintained over the expected load range of the vehicle. Adjustments in height that are necessary to correct height differences between the vehicle's left and right sides for RAS system shall be restricted to what can be reliably achieved with one air suspension height sensor.
The system uses one air suspension height sensor, a steering sensor, generic electronic module (GEM) transfer case inputs, and other vehicle sensors to measure driver and road inputs. The system changes vehicle height using an air compressor, two air lines, and the use of an air spring with an air spring solenoid.
The air suspension system holds vehicle height when the rear hatch or any door is opened. The system stores rear vehicle height the moment any open door is detected. The system then maintains this height regardless of the addition or removal of a load. The system will return to its commanded height when all doors are closed and the vehicle speed exceeds 16 km/h (10 mph).
Air Suspension Switch
The air suspension switch is located behind the RH kick panel on a mounting bracket. The switch interrupts power to the air suspension control module.
The air suspension switch supplies a signal to the air suspension control module. Without the air suspension control module receiving this signal the load leveling system is inoperative and will not react when rear of the vehicle is raised or lowered. If the air suspension system is disabled by turning off air suspension switch, a "CHECK SUSP" will appear in the RH corner of the instrument cluster with the ignition in the run position.
Air Compressor
The RAS air compressor:
  • Is not interchangeable with four wheel air suspension (4WAS) compressor.
  • Consists of the compressor and vent solenoid; neither are replaceable as individual items.
  • Is mounted in the engine compartment between the washer fluid bottle and headlamp (RH front corner).
  • Is a single cylinder electric motor driven unit that provides pressurized air as required.
  • Is powered by a solid state relay, controlled by the air suspension control module.
  • Passes pressurized air through the compressor air drier that contains silica gel (a drying agent). Moisture is then removed from the compressor air drier when vented air passes out of the system during vent operation.
  • Air drier has a single port and is not interchangeable with 4WAS compressor air drier.
  • Air drier may be replaced separately.
  • Incorporates a snorkle that may be replaced separately.
The vent solenoid:
  • Allows air to escape from the system during venting actions.
  • Is located in the air compressor cylinder head.
  • Has a 160 psi internal relief valve.
  • Shares a common electrical connector with the air compressor motor.
  • Is enclosed in the cylinder head casting, which forms an integral valve housing that allows the valve tip to enter the pressurized side of the system.
  • Has an O-ring seal that prevents air leakage past the valve tip.
  • Opens when the air suspension control module determines lowering is required.
  • Provides an escape route for pressurized air that opens when system pressures exceed safe operating levels.
  • Is replaced with the air compressor as a unit.
Air Spring
RAS vehicles use air springs in the rear. The air springs provide a varying spring rate proportional to the systems air pressure and volume. The air suspension system regulates the air pressure in each air spring by compressing and venting the system air. Increasing air pressure (compressing) raises the rear of the vehicle while decreasing air pressure (venting) lowers the rear of the vehicle. Vehicle height is maintained by the addition and removal of air in each air spring through an air spring solenoid installed in the upper spring cap and energized through the air suspension control module.
The air springs are mounted between the axle spring seats and the frame upper spring seats.
The two air springs replace the conventional rear coil springs.
When the air suspension height sensor indicates that the rear of the vehicle is lower than trim under normal driving conditions, the air compressor will turn on and pump compressed air to the air springs. When the sensor indicates that the rear of the vehicle is raised above trim under normal driving conditions, this will cause the air to be vented from the air springs to lower the vehicle back to its trim height level.
One air suspension height sensor is mounted on the vehicle. The air suspension height sensor sends a voltage signal to the air suspension control module. The output ranges from approximately 4.75 volts at minimum height (when the vehicle is low or in full jounce), to 0.25 volts at maximum height (when the vehicle is high or in full rebound). The air suspension height sensor has a useable range of 80 mm (3 in) compared to total suspension travel of 200-250 mm (8 to 10 in) at the wheel. Therefore, the air suspension height sensor is mounted to the suspension at a point where full rear suspension travel at the wheel is relative to 80 mm of travel at the air suspension height sensor. The air suspension height sensor is attached between the No. 5 frame crossmember (upper socket) and the panhard rod (lower socket). Replace the air suspension height sensor as a unit.
Compressor Relay
The compressor relay is energized by the air suspension control module to allow high current to flow from the battery to the compressor motor.
  • A solid state relay is used in the air suspension system for air compressor control. The relay incorporates a custom power metal oxide semi-conductor field effect transistor (MOSFET) and ceramic hybrid circuitry. The relay switches high current loads in response to low power signals and is controlled by the logic of the air suspension control module.
Air Suspension Control Module
NOTE: The 4WAS air suspension control module is used for the RAS system. The internal processor recognizes external circuitry to determine if it is installed in a 4WAS or a RAS equipped vehicle.
NOTE: The air suspension control module is calibrated with information from the air suspension height sensor. A new or exchanged air suspension control module requires a ride height adjustment calibration process to be performed.
The air suspension control module controls the air compressor motor (through a solid state relay), and the air spring solenoids. The air suspension control module also provides power to the air suspension height sensor. The air suspension control module controls vehicle height adjustments by monitoring the air suspension height sensor, vehicle speed, a steering sensor, acceleration input, the door ajar signal, transfer case signals, and the brake pedal position (BPP) switch. The air suspension control module also conducts all fail-safe and diagnostic strategies and contains self-test and communication software for testing of the vehicle and related components.
The air suspension control module is mounted in the passenger compartment inside the instrument panel above the radio and temperature controls.
The air suspension control module monitors and controls the air suspension system through a 32-pin two-way connector. The air suspension control module is keyed so that the air suspension control module cannot be plugged into an incorrect harness. There are two sides of the harness connection to the air suspension control module. Each is uniquely colored and keyed to prevent reversing the connections.
Air Suspension Diagnostic Connector
The air suspension diagnostic connector is used to aid the technician in diagnosing the air suspension system. It is also used to vent the system of compressed air when air suspension system components need to be repaired or replaced. The air suspension diagnostic connector is located under steering column.
Oct 02, 2009 | 1998 Ford Expedition
EXPEDITION REAR AIR RIDE PROBLEM
do you have just rear air suspension? here's rear only. 4 wheel different. Deler an run a diagnostic test with WDS machine and get fault codes.
The air suspension system is designed to improve ride, handling and general vehicle performance for static, on-road and off-road driving conditions:
The system consists of unique rear air springs, the air compressor, air lines, air spring solenoids, height sensor, air suspension control module, attachments and associated signals derived from both driver and road inputs. With these components and signals, the air suspension control module commands changes in vehicle height that are necessary for the load leveling features.
The load leveling feature rear air suspension (RAS) systems shall automatically make adjustments in vehicle height so that the vehicle is always at trim height and constant front-to-rear vehicle attitudes are maintained over the expected load range of the vehicle. Adjustments in height that are necessary to correct height differences between the vehicle's left and right sides for the RAS system shall be restricted to what can be reliably achieved with one air suspension height sensor.
The system uses one air suspension height sensor, a steering sensor, generic electronic module (GEM) and other vehicle sensors to measure driver and road inputs. The system changes vehicle height using an air compressor, two air lines and the use of air springs with air spring solenoids.
The air suspension system holds vehicle height when the rear hatch or any door is opened. The system stores rear vehicle height the moment any open door is detected. The system then maintains this height regardless of the addition or removal of a load. The system will return to its commanded height when all doors are closed or the vehicle speed exceeds 16 km/h (10 mph).
One air suspension height sensor is mounted on the vehicle. The air suspension height sensor sends a voltage signal to the air suspension control module. The output ranges from approximately 4.75 volts at minimum height (when the vehicle is low or in full jounce), to 0.25 volts at maximum height (when the vehicle is high or in full rebound). The air suspension height sensor has a useable range of 80 mm (3.2 in) compared to total suspension travel of 200-250 mm (8 to 10 in) at the wheel. Therefore, the air suspension height sensor is mounted to the suspension at a point where full rear suspension travel at the wheel is relative to 80 mm (3.2 in) of travel at the air suspension height sensor. The air suspension height sensor is attached between the No. 5 frame crossmember (upper socket) and the panhard rod (lower socket).
  • Uneven vehicle height
  • Circuitry.
  • Rear pneumatic fault.
  • Air compressor assembly.
  • Air suspension control module.
  • Go To Pinpoint Test I .
Feb 21, 2009 | 2001 Ford Expedition
Locating the air suspension compressor on 1991 linoln town car
Its under the windshild washer reservoir ,under the hood on drivers side.
Dec 22, 2008 | 1991 Lincoln Town Car
D-Spec Adjustable Shocks/Struts Subaru WRX 02-07 DSP-10 Logo
32 people viewed this question
Top Tokico Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Tokico Vehicle Part and Accessory Expert? Answer questions, earn points and help others
