Question about Aiwa CA-DW50 Cassette/CD Boombox
Tape decks playig too fast
Aiwa ca-dw50: tape players play to fast using tapes prerecorded on other machines
  • 50 Answers
Hi I can probably tell you what is wrong, but there is usually not much you can do except take it to a shop and have the motor replaced. I most cases there is a hole in the back of the cassette capstan drive motor, or on a small circuit board close to the motor where the speed is adjusted at the factory. You could possibly adjust the speed by ear until it sounded right playing a factory recorded tape with a song you know well, but I recommend these adjustments be left to a tech with a frequency counter. Also, these adjustments normally never need to be touched unless replacing a motor, so it is likely something internal has gone wrong with the motor, and it should be replaced under most circumstances. Hope this helps, Good Luck.
Posted on Sep 27, 2007
SOURCE:
Aiwa karaoke machine tape player won't work
chances are a belt drive failure, 1 belt is used for both decks,
you may be able to get a replacement from auction sites but its doubtful
Apr 02, 2014 | Aiwa Audio Players & Recorders
The tape plays songs so fast sounds like donald duck. The speed the tape is feeding is to fast.
Hi, the casette deck has a mechanical system (servo-driver) most of the problems that happen when in your case, plays song so fast is that you look at the pinch roller. The pinch roller is a rubberized free spinning wheel typically used to press magnetic tape against a capstan shaft in order to create friction necessary to drive the tape along the magnetic heads with a normal tape speed if the pinch roller brakes, get lost from his place or got dirty then you get this fast sounds play, check the pinch roller if still good in his place or clean his rubber with alcohol, then the problem should be fixed.
Jan 29, 2011 | Sony CD Radio Cassette Boombox, CFD-E90...
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Tape deck problems Aiwa CA-NSX777
Tape drive mechanism requires service (cleaning and lubrication) and might need replacement of drive belts. Of course its qualified tech job.
Jul 25, 2009 | Aiwa NSX-A777 Shelf System
How do I record from one tape deck to the other?
Put your "blank" in the deck with the record button, normally red button and press rec/play and pause at the same time, put your "origional" in the other deck and press play and pause at the same time, then un-pause both at the same time. Make sure that the hifi is set to tape as if you record tape to tape when listening to radio foe example, you will get a strange "mix tape" of your origional and the radio.
Jun 05, 2009 | Audio Players & Recorders
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Playback speed
Deck probably has a failing drive motor. Take in for service
Apr 11, 2008 | Audio Players & Recorders
Cassette player problem
Sounds like the take-up reel isn't turning. Often the linkage for the take-up reel is used for both Play and Fast Forward. So test the Fast Forward.
I would look for a broken belt or slipping drive wheel. The fact that the tapes are unraveling tells me that the capstan is pulling the tape out of the feed reel.
Feb 09, 2008 | Audio Players & Recorders
Cassette Player Stopped Working
In all likelihood the Drive belts have snapped. Get them replaced.
Sep 24, 2006 | Aiwa XR-C3RW Shelf System
Aiwa CA-DW50 Cassette/CD Boombox Logo
238 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
