Question about Arctic Pro YPC-07C Faac7 Portable Air Conditioner
Need a remotes for my arctic pro faac7 - Arctic Pro YPC-07C Faac7 Portable Air Conditioner
Lowering arcticpro temp.
Find in a manual in advanced setup where you can adjust the maximum and minimum cooling and max min heating. Should be a set point that someone set to where it won't go lower than 76
Jun 05, 2016 | Arcticpro Ypc-07c Faac7 Portable Air...
Wont let me change temp. below 76 degrees on arcticpro
76 f is 24 celsius which is optimum temperature for comfort
ArcticPro portable air conditioner FAAC7. Now need window kit window.Tried some web sites for parts but no luck.i
Your Fridge Electric air conditioner probably was manufactured somewhere in Asia and imported by the distributor in Canton, Ohio. There may be no support available.
Jul 15, 2014 | Arcticpro Ypc-07c Faac7 Portable Air...
Local arcticpro repair
The blue snowflake is for the AC. The 3 fan icons are for low, medium, and high settings. The icon with the cup with over flowing water means empty the water tank. The cup next to the snow flake is the dehumidifier. The cup next to that means tank is empty and the clock is the timer. If the front part is only blowing out hot or warm air I say you got a broken one unfortunately. The back part blows out hot air which is why there is an exhost hose attachment.
You can get the owner's manual here: Arctic Pro 9 000 BTU Portable Air Conditioner FEA4320A Scroll down the page to see the link for the owner's manual.
Jun 20, 2014 | Arcticpro Ypc-07c Faac7 Portable Air...
How or what setting do you turn on to get cold air
Make sure the thermostat is turned to below what the room tempeture is. Make sure that the unit is in the cooling and not just the fan.
Good luck,
Marty
I need a new hose and window panel, where can I get parts?
Arctic Pro would be a good place to start searching for parts
Sep 29, 2013 | Arctic Pro YPC-07C Faac7 Portable Air...
Arctic Pro YPC-07C Faac7 Portable Air Conditioner Logo
Top Arctic Heating & Cooling Experts
Tom Chichester
Bill Boyd
Thomas Woodburn
Thomas Woodburn
Are you an Arctic Heating and Cooling Expert? Answer questions, earn points and help others
