Question about Homelite Garden
Homelite UT10580 chainsaw wont run when hot - Homelite Garden
  • 63 Answers
SOURCE: Homelite 16'' chain saw runs rough and backfires
One of two things is wrong. This saw is so old I doubt it has electronic ignition. Pull the flywheel off and clean the points with carb cleaner and sand the contacts very, very lightly with super fine sandpaper or a little file. Second option, the coil is bad, take it to the shop and they should be able to test it for you.
Posted on Mar 16, 2009
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
SOURCE: homelite runs wide open all the time
intake boot under carb is probably bad, mine did the same thing and this was the problem. about a 6 or 7 dollar fix
Posted on Apr 11, 2009
dontbother10
  • 2220 Answers
SOURCE: homelite xl chainsaw revved up & quit and won't start now
I suspect you have a fuel delivery problem or a dirty carburetor. As a chain saw runs out of fuel they often revv slightly (running lean). HTH
Lou
Posted on Oct 07, 2009
dontbother10
  • 2220 Answers
SOURCE: chainsaw dont run right
Adjust the "H" needle valve slightly more CCW and try it. This is also often helpful.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Lou
Posted on Jan 14, 2010
Homelite 42cc model ut10580 high low jet set settings?how to ajust
try 1 1/2 turns from shut then adjust to get highest revs and richen it a bit till rpm slow. too rich is highest revs. and will burn piston if continued at too lean.
Nov 30, 2016 | Homelite Garden
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
My chainsaw will not stay running and gets hot and wont cut
clean carb,sharpen blades,put chain oil in it
Jul 04, 2015 | Homelite Garden
How to remove sprocket from chainsaw ut10588
Also if yours has a chain brake make it is in the release position. A few of these saws had them but not all.
Nov 20, 2014 | Homelite UT10580 18" Gas 42cc Chain Saw
Homelite ut10580 nut that holes the cluth cover will not tighten
Might be stripped, you sure it's not a left hand thread?
Oct 29, 2013 | Homelite Garden
Races at idle
If the idle cannot be controled by the idle screw ( screw marked with an I or T on the side of the carb ) then you may well have an air leak through a crank seal or a gasket.
Nov 23, 2012 | Homelite UT10580 18-Inch Gas 42cc Chain...
I have a Homelite UT 10520. It is a refurbished chainsaw. It has ru about 30min. It is running hot. My mixtture is 50:1 and my gas is 90 oct. I think it is running lean. It will not get to the max...
lI thinkthe oil to gas is too rich with Gasoline. My book says 40 to 1. Not enough oil will cause it to run hot and burn or stick. Also some of the later models take the synthetic oil andif you use the outboard or other oil it will run hot and ruin the saw.
Jul 07, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Jul 13, 2010 | Homelite Garden
Homelite chainsaw 420
Check to see if the chain brake is engaged
Nov 15, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
23 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
