Question about Manley Banzai Gushing Geyser Bounce House
Bounce house going flat not filling properly nor
Bounce house going flat not filling properly nor can handle any weight
05 buick lesabre steering wheel schimmy at 5 mph
My first guess would be a bad tire. You could have the tires rotated front to back to see if the problem stops.
Mar 04, 2014 | 2002 Buick LeSabre
What's the construction of a medicine ball?
Medicine balls are constructed of leather or vinyl covered nylon cloth, and filled with impact absorbing materials to give them weight. Vinyl covered medicine balls typically are sand filled and are not used for exercises requiring bouncing.
Aug 05, 2012 | Exercise & Fitness
What is a ping pong ball made of and how much does it weigh?
Aping pong ball is made of high-bouncing air-filled celluloid and weighs2.7 grams.
Aug 05, 2012 | Sport & Outdoor - Others
Brakes have locked up after having to hit them hard to avoid a crash. Now they smell and make the car bounce after hitting 45 mph.
sounds like to problems did you actually hit some thing? if not the burnt smell should go away. about the bounce at 45 mph are you sure that it's not a shake and does it go away at 55 mph or different speed? if this is whats happening the front tire is out of balance weight could have fallen off. try this
Aug 16, 2010 | 2000 Mercury Villager
'clunking' sound
Yes, try removing the cat you ran over last week.
Actually, the clunking could be several things. First, check to make sure that the nuts holding the wheels on are very tight. If they are pneumatic, check the tire pressure to see if it is at the proper level. If they are flat-free, these tires won't have valve stems and have a semi-solid core instead of a tube. Chairs that sit in one place over a period of time will develop a flat spot on the tires. Usually, if it hasn't been too long, they will go away with driving and or warm weather and driving, otherwise, you need to replace the offending tire or buy some earplugs.
Sep 28, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Location of drain plug, fill plug and correct oil level plug for 5 speed manual transmission
I don't know if there is a fill plug. I just use the level plug located on driver's side right above the inner CV joint of the half-shaft (axle) to fill it. A piece of flexible tubing connected to a funnel works well. The drain plug is fairly near the center of the bottom of the gearbox housing (behind the bell housing). The level plug has a 24mm, fairly flat, hex head, and the drain plug is a recessed plug with a 3/8" (?) square hole (for a socket handle).
Jun 02, 2009 | 1993 Geo Metro
Washer not finsihing spin cycle and bounces across room
Hi!
The noise could be from loose lower front weight mounting bolts or a loose bolt securing
the driven pulley. Check the belt for a weak seam and replace if necessary. Check the motor adjustment bolt for tightness.
"Ticking or Knocking" Noise In Spin: The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the topcover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Usually felt on the backside of the belt as a "flat" spot. Replace the belt.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud noise/bang from the back of the car when going over bumps
You more than likely have one of two problems. One of your shock absorbers has a broken attachment bracket or 2) You have a broken exhaust bracket to your muffler. To check the shock just have the vehicle on a flat area motor turned off with emergency brake on and go to each side and "bounce" the vehicle using your body weight. Then to check the exhaust do this when motor is completely cool motor off emergency brake on and chock the tires so there is no chance the vehicle will roll. Get under the rear and attempt to move the exhaust assembly. If it moves to any degree side to side etc then it is this. If the vehicle bounces excessively when you bounce on it then it is the shock - repair accordingly. Hope this helps.
Jan 16, 2009 | 1994 Toyota Camry
Doorhandle forced when locked. now it will not open when unlocked
most likely the door frame is out of alignment due to the force of the weight.
you can try to open the door from the opposite side. push instead of pull.
if that doen't work, use a nail and hammer, remove the pins from the hinges pop open the door off the frame. (have someone braced the door before you push it.)
once you have it open check the alignment of the door frame, and realign it as necessary.
Oct 25, 2008 | Hardware & Accessories
Manley Banzai Gushing Geyser Bounce House Logo
13 people viewed this question
Top Manley Toys Experts
chrisapinsen
Level 1 Expert
Stitch85
Level 1 Expert
Mark Schmit
Mark Schmit
Are you a Manley Toy Expert? Answer questions, earn points and help others
