Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Meale dishwashers I have just moved from one house to another. my new house has a one half inch water supply my old houe had 3/4 inch connector When I hook up my dishwasher the indicator light comes on and the washer will not fill. ????????
  • 209 Answers
Check that you have water supply to the pipe that connects the dishwasher to the wall, when you switch the dishwasher on, dose it buzz quietly, if so there is no water coming to the machine, the fault is with the plumbing, if there is no quiet buzz when switched on then check the water solenoid for open circuit if i have helped please rate me
Posted on Sep 29, 2007
  • Anonymous Sep 29, 2007
    sorry i forgot to say, its not the size of the fittings that mater as long as it is adapted somewhere so the water gets to the machine
I have a similar problem with the same model of Miele dishwasher. I figured I should check the circuit to the water inlet - so my question is : where do I locate the water inlet valve? Can I access it from the front panel or do I have to pull the unit out to access the back?
Posted on Oct 08, 2007
SOURCE:
Can a half inch pipe and 3/4 work
Sure you can stay in 3/4 into the house a ways. Some of my plumber friends run 3/4 all the way to the hot water tank. It increases the volume of water. This is particularly effective if there isn't much water pressure. Dropping down to 1/2 inch will increase the pressure. All you need is a 1/2" by 3/4" bushing to drop down to 1/2". I h 7_29_2014_5_47_37_pm.jpg
Jul 27, 2014 | Plumbing
Why is my appartment getting cooler ???
An air conditioner really just moves heat from one place to another. Normally there is an inside unit and an outside unit, or in the case of a window unit, half is inside the room and half outside the window. In either case, it takes the heat from in the room and moves it outside. This portable unit apparently takes the heat from one room and dumps it into another. There is no magic heat elimination - it has to go somewhere.
Jul 01, 2014 | Simplicity 6,000 BTU Portable Air...
I have a quote from a contractor to install a Rinnai R75 tankless water heater. The heater normally requires 3/4 piping. My home has 1/2" piping. The contractor says 3/4" is better but 1/2"...
There are advantages and disadvantages to both pipe sizes. Typically, most houses utilize 3/4 inch or larger to supply high volume circuits like the circuit from the meter (or well) to the hot water heater, outside spigot, or water softener. Distribution from water heaters is usually 3/4 for the main branch but this is reduced for the runs to the sink, dishwasher, washing maching. The reason for reducing the size is to reduce the volume of water in the tube or to reduce the amount of cold water you run down the drain before it turns hot.
Since your house seems to have 1/2 inch supply to the current water heater, I would suggest staying with the current size. The option is to enlarge the tubing from supply to distribution which can be a major plumbing task. If your current water pressure (at the faucet) is ok, then go with what you have.
Jan 31, 2011 | Kitchen Ranges
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 | Dishwashers
No water going in dishwasher, have checked water supply and small filter at the back of machine. water coming from bottom of the machine
This happened to a GE machine of mine once, and the problem was a stuck float..
Inside the dishwasher tub, in the front-left corner under the silverware tray, there's a float that keeps the dishwasher from overfilling. If this is stuck in the "up" position, then the dishwasher will always believe that it's full of water already.
It should be able to move up and down (total travel of 2-3 inches) freely and smoothly.
Best of luck! Add comments back if you find new information, or hit the thumbs-up if this was the solution for your problem!
Oct 19, 2009 | Bosch Dishwashers
Upper spray arm doesn't move. Replaced inlet
Does it feel free to turn? It's water powered and works in conjunction with the water pump. Do you hear the water/booster pump come on?
Oct 04, 2009 | Frigidaire PLDB998A Built-in Dishwasher
New dishwasher no water
make sure water supply on if ok check water solenoid
Dec 23, 2017 | Zanussi 24 in. DE6965 Built-in Dishwasher
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
Dishwasher switched itself off during cycle - no power now
It is possible that some of the pips have been washed down into the drain pump and jammed the impellor, follow the drain hose back to the pump underneath of the dishwasher make sure the d/washer is switched off at the power supply before you attempt this, if you have reasonable mechanical skill you should be able to remove front of pump to clean it.
Oct 09, 2008 | Bosch Dishwashers
GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Mar 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
148 people viewed this question
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
