Question about Samsung Office Equipment & Supplies
Download software for Samsung CLX-3305FW wireless printer
  • 5 Answers
SOURCE: samsung clx-3175fn printer
Direct wireless is not applicable to this model. If you have a wi-fi network set-up, you'll have to use a cable to connect the unit directly to your router then configure the printer to be a part of your network. After that, you should be able to do wireless print.
Posted on Aug 16, 2009
  • 113 Answers
SOURCE: Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Posted on Apr 19, 2010
SOURCE: Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Posted on Apr 30, 2010
pateltraders
  • 35 Answers
SOURCE: setup samsung clx 3170 on shared network
yes
if u use wireless printer u receive n send document via that printer.
Posted on Jun 02, 2010
puertobori
  • 7733 Answers
SOURCE: I need to downgrade to previous firmware for
Unfortunately, once you install a firmware upgrade it is permanent. Driver updates can be reversed but not firmware. That is why you should always have a definite reason for upgrading the firmware.
Posted on Jan 06, 2011
How do I replace/install waste toner tank? Do I have to buy a part?
remove all toners and on the left hand side is the waste ink container. You should be able to simply remove. and yes you will have to order a new one, or try and empty that one
Nov 15, 2015 | Samsung CLX-3305FW Color Laser...
Failing to receive a fax it says received in memory but not printing even when I want to print. Could you please help
Dear Barati
The printer may have some error. pl. check on the display of the printer. After clearing the error the received fax will printed.
Thanks.
Mar 16, 2015 | Samsung CLX-3305FW Color Laser...
HOW I CAN TAKE PRINT OF RECEIVED FAX WHICH KEPT IN MEMORY
it sounds like it is not feeding paper did you try the bypass to feed paper in to the unit? does it copy?
Aug 11, 2014 | Samsung CLX3305FW - CLX-3305FW Wireless...
How do I remove a paper jam?
Dear
Pl. select correct media size in pc/printer as actual media. In general all samsung printers are recover from paper jam on opening and closing of the door. If your problem persists pl. up load a jam paper position photo.
Thanks and Happy new year 2015.
Jul 27, 2014 | Samsung color multifunct laser print...
Samsung CLX-3305FW Imaging Unit error
Insufficient information to answer the problem. Try going directly to their web site http://www.samsung.com/us/search/espsearch.us?keyword=CLX-3305FW+ and check the SUPPORT and FREQUENTLY ASKED QUESTIONS section
May 03, 2014 | Samsung CLX-3305FW Color Laser...
C406 connection problem
Yes Go To Googl Pl*** store download updated driver i would recommend going to printer and Setting But my briain Does not search for that printer is it discontinued? all i see is cartridges (i Nead more info)that is a toner # ) Printers Fr That Toner Is )CLP-360, CLP-365, CLP-365W, CLX-3300, CLX-3305, CLX-3305FN, CLX-3305FW, CLX-3305W; Xpress: C410FW, C410W, hope it helps Donald Deane MCSE,ASE,CPO
Jul 26, 2017 | Samsung Computers & Internet
How to connect printer to iMac
Go to System Preferences--> Print & Fax-->Under Printers click the + button and add the printer to your queue
Jun 05, 2013 | Samsung CLX-3305FW Color Laser...
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
