Question about Hoover SteamVac Spinscrub 50 Carpet Cleaner
The brushes quit spinning - Hoover SteamVac Spinscrub 50 Carpet Cleaner
Dyson brush roller spins intermittently. it starts out good but then stops
Do you have a burning rubber smell at the same time? Turn the machine over and remove the bottom cover. Hook a loop of cord under the belt, pull it up wards and pull the brush out. Remove one end cap and pull the spindle out from the other end. Remove the fluff and hair that is tied around each end.
This shows quite well.
https://www.youtube.com/watch?feature=player_embedded&v=cYqOEpZgocg
Put the brush back and see if that fixes it. If not, then you need to change the two belts, and possibly the clutch. The same guy at Vacuum spot shows clutch servicing, but you may wish to get a professional to do it. How to check the Dyson DC04 Roller Brush Bearings
Mar 21, 2016 | Dyson Vacuums
Hi i have a hoover F5853 when the brushes in contact with the carpet they quit spinning but it is on and lift the front up they start spinning but as soon and i put it back down they quit please help
Belt around brush roller is worn, it spins freely when there is no pressure on it. But put it on the floor, the belt won't turn the brushes. I suggest taking unit to vac repair shop for new belt installation
Dec 05, 2014 | Hoover Vacuums
I have an electrolux precision model EL8805. The brush has quit spinning.. Any suggestions?
- dirt in the moving parts (clean the brushes and area )
- broken gear in the brush?
Oct 16, 2013 | Vacuums
I have a problem with my model 6585-3 bissell upright powerforce bagless turbo with turbo brush vacuum The brush has quit spinning upon removal i noticed that one side of the brush was free to spin the...
Hair and dust build up under the end caps of the brush roll and cause friction. Replace the brush roll and belt. Be sure to clean the brush roll frequently after use.
Jun 24, 2017 | Vacuums
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
Brush spins & then trips & quits
Sounds like a clog to me. Check that the roller brush cap fittings (caps at either end of the brush roll) don't have thread in them as well as checking that the dust channel from the sole plate is completely clear.
Dec 16, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
4296 Robotic Vacuum _ Brush quit spinning
i had the same prob. i contacted i-robot and was told the motor that turns the brush is shot. there is no replacement part. they offered to replace my i-robot with a new one from the 400 series. at about 60% of a new one. that's the only option that i know of.
Apr 09, 2008 | iRobot 4296 Robotic Vacuum
Brushes do not spin on my steam vac
We were having the same problem with the brushes not spinning.
How I fixed it:
I Removed the brush assembly by gently pulling on both sides of the assembly. I took a wide slotted screwdriver and inserted it into the slot (hole) that turns the brushes. At first it did not want to move. I GENTLY applied pressure by turning the screwdriver to get the gear to move and it began to move freely. I spun the gear a number of times using the screwdriver to make sure it was moving freely.
I reinstalled the brush assembly by aligning the gear that slides into the slot and gently pushing the clips back into place using equal pressure on both sides.
I plugged in the machine and the brushes now spin!
Good luck to everyone out there!
Jan 21, 2008 | Hoover F7222-900 SteamVac Upright Vacuum
Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Jan 13, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover SteamVac Spinscrub 50 Carpet Cleaner Logo
116 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
