Question about Homelite Hb-280, Hb-380, Hb-480, Hb-680 Leaf Blower Air Filter Cover A-98133
Fuel mix ratio for hb 380 - Homelite Hb-280, Hb-380, Hb-480, Hb-680 Leaf Blower Air Filter Cover A-98133
2 Suggested Answers
  • 4088 Answers
SOURCE: Fuel Ratio
40:1 is about right. Be sure to use modern synthetic oils made for saws and premix thoroughly before adding to the saw.
Posted on May 04, 2010
What is the fuel mix required for Homelite HB leaf blower?
50:1 is what most modern 2 cycle hand helds use...
Aug 21, 2014 | Homelite Garden
Fuel/oil mixture
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
From Poulan website:
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas. If you have other brands of equipment that require different fuel/oil ratios and you don't want to mix separate fuel cans, you should use the lowest numerical ratio. For example, if you have products requiring 40:1, 50:1, and 32:1 ratios you should use the 32:1 ratio for all products. This may cause slight smoke increase in the exhaust in the 40:1 and 50:1 products due to more oil in the fuel, but it won't damage either of the engines.
Aug 15, 2011 | Poulan Garden
We have a Homelite Leaf Blower HB-180V Please adfvise the correct gas mixture for this product. Thanks. Bonnie Frommeyer
This appears to be an older model, which means more oil was allowed to be mixed with the fuel and the carburetors were tuned accordingly. The EPA has changed all that now. Your mix ratio is listed at 32:1. See the simple chart.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
Jan 11, 2011 | Homelite Garden
Need to make 50:1 ratio mix. what i have on hand is the poulin 3.2 fluid ounce that makes 1 gallon at 40:1. how many ounces of this mix would need to be used to achieve the 50:1 mix ratio.
2 choices here
if you want to use the entire 3.2 oz bottle you need to add it to 1.25 gallons of fuel to = 50:1 ratio
if you have 1 gallon of fuel you need to add 2.6 oz of oil to the fuel to equal 50:1 ratio
hope that helps
Dec 28, 2010 | Poulan 2-Stroke Engine Oil - 24 Pack
Could you tell me what the fuel to oil ratio is for a Homelite HB 180V gas leaf blower? Thanks
40:1 is the ratio. One of those little 2-cycle oil bottles poured into one gallon of gas will give you this ratio.
Sep 17, 2009 | Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
No user manual
Hello:
Most 2 Cycle Engines use a 32:1 or 40:1 Fuel Mix Ratio.
The Newer 2 Cycle Engines use a 40:1 or 50:1 Fuel Ratio.
For Better Performance and to be sure you have Plenty of Oil to the Engines Internal Components, I Suggest (and I Use) a 32:1 Ratio in All my Equipment except for Post Hole Diggers.
Post Hole Diggers Use a 25:1 Fuel Ratio.
Hope this Helps.
Good Luck
Respectfully
John
May 10, 2009 | Garden
Homelite Hb-280, Hb-380, Hb-480, Hb-680 Leaf Blower Air Filter Cover A-98133 Logo
79 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
