Question about Kodak Photography
Projection lamp will not contact with supply....how to fix
Change lamp in hitachi 42v515
the lamp ,unit price is USD120
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Nov 09, 2013 | Hitachi 42V515 rear projection TV lamp...
How to check sony projector lamp
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
have a nice day!
Jerry Lampdeng Limited
Apr 16, 2013 | Samsung - Projection TV replacement lamp...
I have a 55vf820 projection tv but the picture is dark whats the fix?
you need a new lamp, USD130, original one
have a nice day!
Dec 17, 2012 | Hitachi Lamp For Hitachi 55VF820...
Tv pops on and off suddenly after viewing for about 10 to 15 mins. this problem becomes progressively worst after prolonged viewing. as of today there is absolutely no picture and or sound.
Your symptoms exactly match this scenario: a component involved in picture & sound was failing intermittently, then progressed to a hard failure.
My suspect: a power capacitor in the power supply. They sometimes fail this way - when the dielectric breaks down completely, then the power supply fails, causing no pic/sound.
Fix: replace power supply (or the specific capacitor, if you can determine which one died).
Oct 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv not comming on red light blink 3 times stop then blink a gain 3 times
I do not agree with previous expert solution because it is not power supply/ power board failure in tv.
I think lamp was taken out from tv or may be it was replaced.
Check lamp cover in your Sony tv that is not fixed properly on its position. Make sure lamp cover is fixed securely.
Sep 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Want to find out why the 42' samsung projection tv doesnt come on any more could it be simple fix like bulb
The first thing to try is the bulb. If that does not fix it then it is time for a technician to figure it out.Other things it could be are the ballast, power supply board, color wheel or the DMD board; but I would try the lamp first.
Jun 09, 2010 | Samsung - Projection TV replacement lamp...
This is a power board going to the lamp of the DLP MITSUBISHI TV I HAVE THE NEW LAMP BUT THERE NO POWER GOING TO THE LAMP THE TV HAS POWER IT WON'T LIT THE SCREEN
there are bad capacitors on the power supply.
look for bulged caps
they look like this
replace the big ones on the power supply to fix the lamp issue
there are more bad ones inside typically on the dm and fmt boards
they are 1000uf - replace those ones with 680uf @ 16v caps
let me know if i can be of further assistance
Jun 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Lamp power supply board on Panasonic PT-50LC13 mulfunction.
You can purchase the lamp supply thru "Encompassparts.com... The cost is $100.00, there is a $250.00 core charge on that module, so when you return the old they refund the 250. Initial investment will be 350.23 then take the 250. off that. That will be the end cost.
Part # LSEB3087A
Apr 16, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Green haze projected on wall
the Lcd panels were broken, you need a new one,USD120
have a nice day!
Oct 26, 2008 | Sanyo LAMP Projector Lamp FOR...
Photography Logo
29 people viewed this question
Top Kodak Photography Experts
Michael Galve
Michael Galve
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
