Question about Miller Welding Tools
Calibrate? Welder runs hot then cold then hot power stays the same
I like to know why my mig welder burns real hot sometimes or real cold.
Ya, it's been some time since I've welding days but I used to do a bit. Here is a video that might help you out quite a bit.
Hope this helps you out, thanks for using FixYa.com
Feb 19, 2017 | Welding Tools
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
Oct 03, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
I have a lincoln sp100t wire welder, it will not run a hot bead,last time i used it I could set it at max heat and low wire speed and i could run a fairly good bead. Could it be a bad capacitor, or...
Check your power outlet and do not use. an extension cord. T :) e welder draws 20 amps and a normal home outlet is 15 amps. So get as close to you incoming power supply as you can.
Feb 11, 2015 | Lincoln Welding Tools
When i plug welder in it blows the house electric.anybody got any ideas what the problem is?
pulling to many amps out of your house turn stuff of and dont run your welder so hot anythin your not useing turn off before welding
Dec 09, 2010 | Clarke Power Products Mig/Fluxcore 180En...
Have HP3600n over just 1year. Having trouble after startup gets stuck in calibration and won't go any further... any thoughts? Have tried cold reboot w/all unplugged several times...Mike
Start by removing the formatter. Have paper in tray 2.
Print an engine test. You should see repeating lines of cyan, magenta, black and yellow. If any of the colors are missing - run the Disable Cartridge Check. Run the engine test again with the previously missing color in another slot. If that color fails again, replace it. If the issue stays with the slot replace the laser scanner. If the engine test is good now, install a new formatter, power up and see if the calibration hang is gone.
Jan 26, 2010 | HP LaserJet 3600n Printer
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Soon as i let off the eccelerator it stalls wont stay running unless foot on the gas
Pull AIS (automatic idle speed) or IAC (idle air control) motor off, clean with carb cleaner or throttle body spray cleaner, as well as port it came out of & see if that doesn't help or cure it. If it cures it for a while, then starts to do it again, replace it. (located on side, at front part of throttle body usually.)
Aug 01, 2009 | 2001 Dodge Dakota
Welding Tools Logo
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
