My Nokia N95 keeps dropping calls more and more. Yesterday it turned off while making a call.
Friend the problem is your battery.change it with new one.it is already drain.
I see. Friend:the problem is your phone is the hardware sad to say.they
are the so called P.A. power amplifier and the antenna switch.either of
the two is both damage or malfunctioning and needs to be replace and
reheated or resolder. these two hardwares brought you signal.the
antenna switch the one the that will pick up the signal.while the P.A.
is the one to process the signal to the audio. either of the two that
will damage can cause the signal dropped or cut off. Friend you need
mobile phne technicians to solve this problem.ask for their
assistance.good luck
The battery is fine (it is relatively new. The phone holds a charge perfectly and the phone's signal and battery are usually both peaked out at full-power when this happens. I had the rare chance to see the signal bar when a call was dropped, and it completely went to zero signal and back to full bars in a second's time. I think I will try the battery though (just to make sure).
