Question about Bell Cocoon Child Carrier
Hpm d641/blr manual - Bell Cocoon Child Carrier
2 Suggested Answers
SOURCE: I need instructions on how
I have a copy here . Hope it helps.
Posted on Jun 03, 2011
How do I set a 24 hour timer D809/1
HPM 24 hour timer instructions: rotate dial clockwise until current time lines up with pointer located on inner dial. There are segments located around edge of dial. Pull up these segments to set on-off times. Turn Load switch ON. Plug Load into timer. Plug timer into receptacle. Manually rotate dial clockwise and observe Load turning ON-OFF. This will show if timer is ON or OFF when segments are pulled up.
I think the D809/1 has 15 minute intervals. The only manual on the HPM site for a 24 hour timer close to this is:
https://hpm.com.au/app/document/asset/23/16/6/d8180d-hpm-24hr-outdoor-timer-instruction-sheet.pdf
Sold at Bunnings in Australia, you might find a manual with one! Alternatively, here is another place they are sold and given they are inexpensive, it might be worth it to just get the instructions. Amazingly, if you try to search for a manual for this, you can not find it. You just get comments like the techs were not help, the manual was in Chinese, and after translation, were not even understood by the techs. Heaven knows what the truth is. The HPM manual above is clearly in English. Note the device manual above likely is set for half hour intervals. Good luck.
http://www.radioparts.com.au/ProductDisplay.aspx?popup=1&Category=SXKK1045&Product=49161200&ProdDesc=D809%2F1+24+HOUR+ANALOGUE+TIMER+HPM
Aug 11, 2017 | Hardware & Accessories
How do I get a manual for a Baby Lock Ellure BLR sewing machine?
just go to babylock.com and type in Ellure blr manual. I would have posted the link for you but the response text box on fixya kept telling me I was using "invalid words"!
Oct 08, 2014 | Baby Lock Ellure
Instructions to operate hpm d817 dusk
1) Copy following link to identify timer and download instructions for D817DUSK timer from Legrand-HPM:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
2) Add comment and include photo of timer
Dec 11, 2012 | Hardware & Accessories
D641/BLR DOOR CHIME CHANGE CHANNELS
Open the back of the door chime and the button press.
On the back of both of them there is a set of jumpers.
From left to right there are 6 available frequencies. You need to grab to jumpers to join 2 of the pins together (top and bottom pin). If you don't have a jumper just use a set of pliers and cross the 2 pins together (top and bottom pins) on a channel you wish to use. Repeat the process for the button press if you've just done the door chime. The 2 pins that you've joined together needs to be the same as you've just done for the door chime.
Note the red jumper on the button press, selects the type of door chime you want to hear. this is the 4 right hand side pins on the button press. The far right is a long chime and second in from the far right is a shorter chime.
Hope this helps, figured it out by trial and error. :)
Sep 19, 2012 | Bell Cocoon Child Carrier
Hpm 24 hr manual timer , i dont know how to get it working
HPM 24 hour timer has segments located around dial.
http://waterheatertimer.org/Woods-timers-and-manuals.html#HPM-dial
http://waterheatertimer.org/images/hpm-24hr-timer-500.jpg
Segments appear to move up or down.
Other similar timers: Segments down = Load ON; Segments up = Load OFF
Press several segments down.
Plug timer into wall.
Plug 240Volt load into timer.
Manually rotate timer dial clockwise to see if segments down turn load on or off.
There is also a 2-position slide-switch located on top of timer.
Move slide switch to each position to see which is need for timer to turn load on-off.
After positions are defined, push segments down or leave segments up for times you want load to turn on.
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Timer dial rotates as time passes, and segments move a plastic lever that turns load on and off
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 20, 2011 | Hardware & Accessories
HPM D817/2 electronic timer 7 face buttons, Manual required. Thanks
1) I have located a similar timer, with similar buttons.
Tork 451D with manual:
The buttons are in different order, and Tork is 120Volt timer, not 240Volt like HPM.
This information may help if you have HPM timer and can experiment.
I doubt this information will help if you are simply looking for a clear cut 1:1 manual to sell on-line.
2) The HPM timer does not sell in US, but the timer is inexpensive and you can purchase the timer for $27 and scan manual into pdf format.
3) HPM also has a contact us page, but I don't know if they will send manual of if link is good:
http://www.hpm.com.au/Products.aspx?pid=18#Timers/Timers/7-Day-Timers
Dec 26, 2010 | Hardware & Accessories
Remote doorbell not chiming.
I would recommend replacing the battery in the remote button. There may be enough battery power to light the light, but it usually takes a bit more to transmit the signal to the main unit.
Apr 19, 2009 | Audio Players & Recorders
Bell Cocoon Child Carrier Logo
24 people viewed this question
Top Bell Sport & Outdoor - Others Experts
Are you a Bell Sport and Outdoor - Other Expert? Answer questions, earn points and help others
