Question about Acer Aspire One PC Notebook
Screensaver set I let my little brother see it and he messed up the settings so my screensaver is totally black and i can not change it.
  • 52 Answers
Hi, go to start- Control panel- personalization. Click here and check if the
screen saver is turned off. It is located on the lower right corner. Click on it
to turn the screen saver back on. This is for windows 7.
If you are running XP go to Start- Control panel- Display. Click on the
display icon and there is a tab that says screen saver. Click here and chose
your screen saver.
Posted on Oct 19, 2013
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Tip
My Pictures Slideshow screensaver
Make use of the Windows XP's My Pictures Slideshow screensaver for this purpose. Follow the steps:
Using Paint brush (mspaint.exe), create 10 or more images with a Black background in each. Open each image file and embed your company logo in it, in (place it in random areas, one in each image).
Create a folder for the image files you've created, and place the images in that folder. Assign this folder read-only permissions for all the users.
Now, configure the screensaver under your user profile. In the My Pictures Screensaver properties, do the following:
Set the folder where you've stored the image files
Set the interval using How often should the pictures change slider.
Uncheck all the checkboxes at the bottom of the dialog
Click OK and save the changes
Set the Screensaver Timeout to a preferred value in minutes
Test the Screensaver in your profile to see everything is fine
My Samsung Galaxy Y (GT-S5360) gets this wierd screensaver like thing with "FREE" across in and a red ribbon. After that "Samsung Galaxy Y GT-55360" appears in a static screen. This happens continu
it is a scansaver problem,you going to your extra scansaver setting portion and fixed your setting or it found your display setting portion there having a part "image change" you click that and set your problem.
Mar 26, 2013 | Samsung Galaxy Y Gt-s5360 - Black unlocked...
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Cant print in black and white when out of a color.
disregaurd any prior solutions in cleaning any contacts. that model doesnt have an electrical contact to clean. there are little magnets inside each color and black cartrige that work off a float mechanisim inside each one. when the levels get low the magnet indicates to the printer it is empty. unfortunately for you this stylis model as with all brother model printers wont work even if the color your setting up in the properties or settings feature are set to black and the black is full. its the companies way of forcing you into buying new ink. be aware though that my brother catriges cost 78.00 for the 3 color and one black set. i found these cartriges online through ebay but with one more additional black cartrige for a total of 5 not for ,for a total cost of 13.11 with free shipping. sounds too good to be true but for 13.00 it was worth a try. i have now purchased several 5 packs from them and couldnt be happiere.
Jul 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Little brother
If you could change channels with a remote, you probably don't have, and never had, a dial which you rotated to change channels. There should be buttons on the front of the set, one or two of which will change the set from game mode to tv receive mode. Turn the set on and just try pushing one button at a time until you hit the right one. If you don't see any such buttons, there is a panel on the front that is covering them. Either open the panel by hand or push on the panel and it will spring open and reveal the buttons.
Good Luck.
almarc13
Mar 10, 2009 | Philips Magnavox 27MS343S 27" TV
Getting frequent black screens on 1501 Inspiron Laptop
Black screen is probably a screen saver or the screen is turned off by power management software.
Check your screensaver setting. Change the screensaver to None to disable screensaver.
I assume you are using Windows XP.
If the LCD is turned off by power management, on the same screen with screen saver, on the lower part of the box there is a Power button. Click to open Power Options Properties. Set your monitor power properties there.
When the screen go blank and you have to push power button, probably the computer is set to go to stand by mode after some idle minutes. You can also set it here in system standby setting.
Regards,
Dapid Candra
Dec 08, 2008 | Dell InspironTM 1501 Notebook
Mfc-115c brother printer
there is no "reset". If you have done settings within the maintenance mode, the settings will be kept!
Mar 06, 2008 | Brother MFC 210C All-In-One InkJet Printer
No Signal
Your brother might have selected offline mode on ur handset and u change it to norrmal mode,, and selected network manualy then it will work,
Sep 06, 2007 | Nokia 7373 Cellular Phone
Acer Aspire One  PC Notebook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
