Question about Lorex Home Security
7 cameras went out in a period of 30 minutes - Lorex Home Security
  • Eric Spencer
    Eric Spencer Jan 14, 2014
    Hi Terry Richardon , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Has this been resolved?
Why won't my camera turn on after putting a new battery in it and charging it?
sell battery on ebay and cuck the camera LOL best one I have
Aug 20, 2014 | Nikon Coolpix S3300
Our detecter reads from 10 to 12 what levels are dangerous?
A Reading of 10-12 is nothing to be worried about.
Thirty-five ppm in an 8 hour period, is the maximum exposure allowed by OSHA in the workplace.
100 ppm Slight headache within 2 to 3 hours
400 ppm Frontal headache within 1 to 2 hours, Widespread headache within 2.5 to 3.5 hours
800 ppm Dizziness, nausea, convulsions within 45 minutes
1600 ppm Headache, dizziness and nausea within 20 minutes, Death within 1-2 hours.
3200 ppm Headache, dizziness and nausea within 5-10 minutes, Death within 1 hour.
6400 ppm Headache, dizziness and nausea within 1-2 minutes, Death within 25-30 minutes.
12,800 PPM Death within 1-3 minutes
Dec 17, 2010 | Kidde Nighthawk Combo Gas/co Detector
How long does the soak programme last?
For this machine the length of time of between 30 minutes and 2 hours can be programmed in 30 minute increments for the soak process.
The machine is set ex works with a soak period of 2 hours.
To programme in a different soak period see "Programmable functions - Soak" in your user manual. See Page 59.
Oct 16, 2009 | Miele Novotronic Premier 500 Front Load...
What is the minimum off time required for the AC used in homes.
NO,IT DOSE THIS TO KEEP THE COMPRESSOR FROM OVER HEATING
Aug 20, 2009 | Kenmore 75085 Air Conditioner
Short battery life
Use the best name brand batteries you can find. Energizers and Duracell work best. Chance the size of your pictures to the smallest you can. At 300 X 300, you can still make 8 X 10 enlargements clearly. The larger the pic, the more power it takes to process it.
Aug 09, 2009 | Canon PowerShot A570 IS Digital Camera
Canon 100D telling me its busy for 2 weeks
Alright, so well I just got off information from canon support, and they said to hard restart (1. take out batt/memory card 2. turn the camera to on. leave for 20 seconds 3. press shutter button 6 times 4. let sit for 30 minutes) Then to use it after those 30 minutes. If it doesn't work, just send it into canon.
Feb 13, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Samsung 15' sync master monitor
Hi...there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it...
Dec 01, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Auto Power Off function?
To conserve battery power, the camera will shut down if an operation is not made within 3 minutes (default setting). The auto-power-off period can be changed in the setup mode to 1 min., 10 min. or 30 min. at user's option. When using the AC adapter, the auto-power-off period is set at 30 minutes.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Is the auto power save function employed?
Yes, this camera has an auto power save function to save power.The camera turns off the displays and unnecessary functions if an operation is not made within a minute. (Power Save Function).To restore the power, press any button or key, or turn the exposure mode dial to another position.The length of this period is selectable from 1 min., 3 min., 5 min., or 10 min. in the section 1 of the setup menu.The LCD monitor always turns off if any operation is not made in a minute, and this period cannot be changed.If no operation is done within 30 minutes, the camera shuts itself off. Pressing the power button resumes the camera operation from this condition.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Home Security Logo
18 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
