Question about Smartpool Pool & Spa
Rotaform evolution spa pool - Smartpool Pool & Spa
2 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Posted on Jul 14, 2010
Whats the difference between pool t-stat and spa t-stat?
when in tstat mode with pool only hooked up turn heater all the way up to 104 keep on pool the control will turn heater on and off using its temp readings
Sep 14, 2017 | Hayward Pool & Spa
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
Jandy one touch control panel model 8156 - spa turns on when pool is on
if you have a 4 button spa side remote unplug if it goes away replace spa side remote
Aug 03, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Spa empties into pool when pool filter is on
That is because the return line to the spa and pool are on. This is expected behavior. This is to keep water circulating.
Jun 12, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Pump surging, air bubbles in return
You have a leak in the suction allowing air to enter and emasculate the pump - find it and fix it!
Jan 19, 2011 | Sta Rite Pool & Spa
Hi! I have a Hayward Pro pool/spa system with Jandy valves and I'm trying to figure out how to switch them from pool to spa. Either I empty the spa or I'm heating the whole pool. Help please!
This is tough cause I can't see the valve setup. I have to assume they are manual valves. Normal operation probably takes some water out of the pool and spa than puts it back into both. To heat the spa, set the intake valves(the ones in front of pump) to take water from only the spa. Set the jets(valve(s) on output side of filter) to send water back to only the spa. The pool will be out of the loop. Normal operation usually has water taken out of pool and spa than put back into both. Make sure to put more water back into spa than you take out, (Adjust valve)
Apr 23, 2010 | Hayward SAND FILTER, PRO SERIES
I want to heat the pool from the spa. I have the spa and spa heat on but the spillover wont come on when I have the spa on. When I turn the spa off the heat goes off. What do I do
When your system is put into Spa mode the system draws water from the spa only to the heater to keep the spa at temp, this is why the overflow doesn't work and why you can not heat the pool in spa mode. If you could heat the pool this way it would take a very long time, since the spa is smaller then the pool. You can heat the pool and spa at the same time in pool mode. Water is pulled from the pool, heated and goes back into the pool and spa.
Mar 27, 2010 | Jandy AQUALINK RS TELELINK KIT
Why does the spa empty when the pump shuts off? just got a pool with an aqualink RS4 and no manual to look at. thanks
This problem can be caused by a couple things. the two most likely culprtits are either the absence of check valves and or incorrect actuator settings when the pump shuts down.
Your spa is most likely higher than the pool. You most likely have a spill over (waterfall) feature from the spa into the pool. This is so the spa water can be recirculated in pool mode. One of your actuator valves may be slightly off closed position in order to allow spill over in the spa, or you may have a dedicated overfill pipe in the circuit to feed water to spa in pool mode.
Whichever spill over piping you have set up, when the pump shuts down, water from the spa ( higher level than the pool) will backfeed through the overflow spa circuit, back through the pump and into the pool through either drain or return. Effectively rendering your spa level the same level as your pool.
To fix this problem, simply install check valves into the spa runs and as a secondary measure put one into the pool return run ( the run that feeds water to pool).
This will insure that when the pump shuts down, no matter which position the valve actuators may be set, water can not back feed through the pump circuit from spa to pool.
Jul 15, 2009 | Water Pik Aqualink Rs4 Package - Pool and...
Pool & Spa Logo
138 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
