Question about Sport & Outdoor - Others
Putting up a vacationer tent - Sport & Outdoor - Others
How do i put up a tent
Jo, you gave no make or model #, so Check the attached links,instruction and guides, the last link shows different type which you can google search for setup also.Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wilderness Survival How to Put Up Dome Tent
How to set up 4 man tent
Instructions for Putting Up Camping Tent
Types of tent
Apr 05, 2016 | Sport & Outdoor - Others
Need instructions for putting up a tent please
I don't know what kind of tent you have but there are many videos on youtube.
erecting tent YouTube
building tent YouTube
making tent YouTube
Aug 15, 2014 | Sport & Outdoor - Others
How do i put buzz lightyear tent together
If it is like mine (year, etc) you simply first lay out the ground cloth (if you have one) long-wise, then lay the tent body on top of the ground cloth. Next, stake out both ends of the tent (at head and feet of tent). Now put your poll sets together (the large one is for near the head of the tent, the short for the near foot of the tent). Go ahead and put the polls in the aligned grommets (matching the ground cloth grommets with the tent-body grommets). Once you have the two polls inserted, then clip your tent to them. Now, with your tent erect, Place your fly on top and drape over the tent accordingly; then fasten the fly to the tent using the belt-type nylon clips to do so. In this case the fly does not need to be "staked", rather "belt-clipped" together instead. That's it, your're done. Don't be alarmed if your tent floor seems as though it's lifting off the ground in some areas, this is normal. Just go ahead and put your bed role in the tent and prepare your area as normal.
Aug 08, 2012 | Playhut Disney Pixar Toy Story Buzz...
Can I use a grill under my tent?
Absolutely not, the smoke from a grill will damage the fabric of the tent. All grills must be far enough away from the tent so that no smoke is allowed to enter the tent. The tent is made of very flammable fabrics so there is a great risk of causing a fire while grilling under a tent, just put the grill outside it will be more pleasant to stay inside not smoky tent.
Jul 31, 2012 | Camping, Backpacking & Hiking
Can I heat up my tent?
Colman and other manufacturers sell tent heaters. Use appropriate caution with heat around synthetic tents, and with fuel-burning appliances inside a tent. RTFM (Read the Flipping Manual!)
Jul 30, 2012 | Camping, Backpacking & Hiking
Disney car tent assemble
I couldn't find the instructional manual, but I did find this image from another answer on FixYa that may be helpful: http://www.fixya.com/support/t9852139-assembly_instructions_disney_princess
Most dome tents are assembled by feeding the rounded (or bendable) poles through loops on the inside of the tent cover. Small connectors and joints should be included to put the poles together into the shape below. Good Luck!
Jul 09, 2012 | Disney Cars 2 Bed Tent with Pushlight
Coleman cobra 3
I wasn't able to find the manual for this exact tent, but you can find the instructional pdf for a very similar Coleman tent here: http://images.owneriq.net/download/images/a/a2b135c5-2f4c-f344-4952-99319efb54aa-000001.png
The video below may also help you see what the tent looks like once it has been put together (different angles may be helpful). Best of luck!
Jul 08, 2012 | Coleman Cobra 3 Three Person Backpacking...
I have an Outbound Sierra-1 tent with no instructions for putting it up, can you help?
Lay the tent out. Thread the black poles diagonally and the grey through the front. Insert a pin to one of the black poles and then work the tent to the other end. Then put the other pin in by gently bending the pole. Make sure the tent is smoothed out as you bend it. Then insert a pin to the other pole. Lift the tent up with the fully connected pole and then smooth the tent out over the other pole. Do the same operation with the grey pole. Tie the tent up in the middle to the black poles. Attach the 'flysheet'. Then peg out the guy ropes.
Jul 31, 2011 | Sierra Tent
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
