Question about Dehumidifiers
My dehumidifier Blyss WDH1012EA need to reset.There is a continuous flashing light warning that the water tank is full,but the water tank is empty.Please help how to reset and made the dehumidifier work adain.
  • 184 Answers
SOURCE: Fedders Dehumidifier
ALL DEHUMIDIFIERS REQUIRE ROOM TEMPS TO BE AT LEAST 65 DEGREES AND A HUMIDITY OF AT LEAST 50 % TO OPERATE PROPERLY. ANYTHING LESS AND IT MAY FREEZE THE EVAPORATOR COILS. EVAPORATOR COILS WILL ALSO FREEZE IF THE COILS ARE DIRTY AND HAVE RESTRICTED AIR FLOW.TRY TAKING THE COVER OFF OF THE UNIT AND CLEANING BOTH SETS OF COILS INSIDE. THEY ARE COPPER OR ALUMINUM WITH FINS ON THEM.
ALSO CHECK THE FAN TO BE SURE IT IS RUNNING.
THAT WILL CAUSE AN OVERHEATING CONDITION AND WILL SHUT DOWN THE COMPRESSOR ALSO.
Posted on Apr 08, 2008
  • 420 Answers
SOURCE: 'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Posted on Jun 04, 2010
SOURCE: my zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Posted on Oct 03, 2010
  • 4736 Answers
SOURCE: This dehumidifier continues to run after it is
Diane, the float valve in the left top of the bucket (it's styrofoam) is stuck and can't shut the unit off when the bucket is full. To help you solve this, I am providing a link to your Owners Manual that will help you with this problem You can download and print the manual for future reference Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to solve this problem.
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Hope this helped you to solve the problem. Please take a moment to rate my response to you.
Thanks.
Posted on Apr 28, 2011
  • 4736 Answers
SOURCE: The water won't run continuously
Some dehumidifiers don't require that the bucket be in place, when a drain hose is attached to the unit. I'm not sure that's the case with yours, because I'm unfamiliar with the Westpointe brand. You should also check the drain connection that the hose is connected to. It may be clogged, which forces the water into the bucket instead of draining through the hose. If you have something flexible like a long plastic Zip Tie, that can easily be run into the hose connection and slowly pulled back out, while rotating it should loosen any clogs. Be prepared for water to follow. Do not use a wire coat hanger to do this and be sure the unit is OFF and unplugged from the wall, before attempting it.
Hope this helped you to troubleshoot and solve the problem. Please let me know.
Posted on May 03, 2011
Testimonial: "That worked.....unclogging the hose. Thanks!"
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Need a Blyss dehumidifier instruction manual
I would look on line try Manual Blyss model number
Jan 26, 2014 | Dehumidifiers
My dehumidifyer won't continuously run
HI,
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care
Aug 11, 2010 | Whirlpool Dehumidifiers
Unit wont turn on,,, water full light flashing
is it full of water if not maney times it senses a full tank by a scale on the bottom of the water pan try to pull up on the plate where the bucket sits make shure its not stuck let me know pls jason
Apr 08, 2010 | Maytag M7DH45B2A Dehumidifier
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
A red light saying full is on. what does that mean? this is a Westpointe de-humidifiier
it means you tank is full of water and needs to be emptied
you can slide it out, dump the water ( i use it for my garden)
then replace the tank
the light should go out
Oct 09, 2009 | Midea MDC-45AE Dehumidifier
Newair ADS-300 Dehumidifier
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Bogus 'Full' warning
or you could just tape the bucket in place. when the compressor kicks in the unit vibrates which might be shacking the bucket loose to the point that it doesn't make contact with the switch.
Jul 02, 2006 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
204 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
