Question about Dehumidifiers
Blyss WDH1012EA dehumidifier 10l
I have a problem.there is a continuous red flashing light worning that the water tank is full.But the water tank is empty.i cannot reset and switch on the dehumidifier.please help.
  • 184 Answers
SOURCE: Fedders Dehumidifier
ALL DEHUMIDIFIERS REQUIRE ROOM TEMPS TO BE AT LEAST 65 DEGREES AND A HUMIDITY OF AT LEAST 50 % TO OPERATE PROPERLY. ANYTHING LESS AND IT MAY FREEZE THE EVAPORATOR COILS. EVAPORATOR COILS WILL ALSO FREEZE IF THE COILS ARE DIRTY AND HAVE RESTRICTED AIR FLOW.TRY TAKING THE COVER OFF OF THE UNIT AND CLEANING BOTH SETS OF COILS INSIDE. THEY ARE COPPER OR ALUMINUM WITH FINS ON THEM.
ALSO CHECK THE FAN TO BE SURE IT IS RUNNING.
THAT WILL CAUSE AN OVERHEATING CONDITION AND WILL SHUT DOWN THE COMPRESSOR ALSO.
Posted on Apr 08, 2008
  • 117 Answers
SOURCE: red light is flashing on my Zenith dehumidifier
take out bucket and locate bucket full switch, depress it, if unit works you will need to add shim to bucket to hold it in.
Posted on Jan 05, 2010
  • 420 Answers
SOURCE: 'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Posted on Jun 04, 2010
SOURCE: my zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Posted on Oct 03, 2010
  • 4736 Answers
SOURCE: This dehumidifier continues to run after it is
Diane, the float valve in the left top of the bucket (it's styrofoam) is stuck and can't shut the unit off when the bucket is full. To help you solve this, I am providing a link to your Owners Manual that will help you with this problem You can download and print the manual for future reference Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to solve this problem.
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Hope this helped you to solve the problem. Please take a moment to rate my response to you.
Thanks.
Posted on Apr 28, 2011
Red Lite is flashing, unit will not turn on
if the red light is flashing this means theres a fault , most common fault on these are water catch bucket is full or not seated back correctly
Aug 24, 2015 | Amana D950EP Dehumidifier
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
I have a Silhouette dehumidifier model # DDR583R which is about 2-3 yr old. The red light indicating a full tank is on and no water is collected. When I checked the sensor & manually pushed it the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 26, 2010 | Danby DDR583R Dehumidifier
The red indicator light just flashes when i turn the unit on. Whats wrong?
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Good luck.
Aug 12, 2010 | Kenmore 54351 Dehumidifier
Unit wont turn on,,, water full light flashing
is it full of water if not maney times it senses a full tank by a scale on the bottom of the water pan try to pull up on the plate where the bucket sits make shure its not stuck let me know pls jason
Apr 08, 2010 | Maytag M7DH45B2A Dehumidifier
A red light saying full is on. what does that mean? this is a Westpointe de-humidifiier
it means you tank is full of water and needs to be emptied
you can slide it out, dump the water ( i use it for my garden)
then replace the tank
the light should go out
Oct 09, 2009 | Midea MDC-45AE Dehumidifier
"running" light on but motor doesn't engage
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 24, 2009 | Haier HDN455 Dehumidifier
Newair ADS-300 Dehumidifier
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Dehumidifiers Logo
784 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
