Question about ViewSonic PJD6241 3D DLP Projector
PJD6241 Bulb light will not turn on after i replaced it
LAMP AND HEAT LIGHT ON
you need to reset the lamp timer
the manual will tell you how to do it
I am glad to send the user manual to you ,if you need
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 16, 2014 | ViewSonic PJD6241 3D DLP Projector
My viewSonic PJD6241 Projector Model VS12476 DLP is not connected by power
1,is the power line is OK?
2,if the power line is ok, it means that the projector is defective
3,the mainboard or main power of the projector is defective?
Feb 09, 2014 | ViewSonic PJD6241 3D DLP Projector
How to replace bulb in front bumper turn signal housing 1995 jag xj6
hello,
  • Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
  • Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
  • Remove the front turn signal light unit in the bumper to change the turn signal bulb. Push gently on the inside edge and insert a blade between the bumper and the lens at the outside edge. Compress the spring and remove the lens. Fit a new lamp by inserting it into the plug. The side marker light is changed using a similar process.
  • Open the trunk to replace the rear fog light, stop light, tail light, reversing light and turn signal light. Remove the rear light cover and turn the bulb holder fastener 90 degrees counter clockwise. Remove the expired bulb, fit a new one and replace the parts, turning the bulb holder clockwise.
  • Thanks..
    May 21, 2011 | 1995 Jaguar XJ6
    Change out a taillight
    You want to change the tail light bulb?
    The process for replacing tail light bulbs is the same in all models. If you have a burnt-out tail light bulb, you may need to replace the brake light, the reverse light or the turn signal. The procedure to replace each of the bulbs is the same.
      Instructions
      1. Open the Hummer's rear swing gate. This will expose the edge of the vehicle's tail light assembly. You'll see two small Phillips head screws that hold the tail light assembly in place. Put on your gloves.
      2. Remove the two screws from the tail light assembly. Pull the tail light out and inspect the back for two bulbs. The top bulb is the brake light and turn signal. The bottom bulb is the reverse bulb. Determine which bulb you need to replace.
      3Rotate the bulb's socket counterclockwise to disconnect it. Unplug the bulb from its socket.
      4Push the replacement bulb into its socket firmly. Insert the socket back into the tail light. Turn it clockwise to secure it in place.
      5Place the tail light into its cradle. Hold it with one hand and replace the Phillips head screws with the other.
    Dec 03, 2010 | 2008 Hummer H3
    2000 pontiac montana. I want to replace the driving ligh bulbs. the under the headlights what size is it?
    Fog/Driving Light Bulb Size: 880
    Here is the rest of the bulb size used in your Montana.
    2000 Pontiac Montana Auto Light Bulb Diagram
    Low Beam Headlight Bulb Size: 9004
    High Beam Headlamp Light Bulb Size: 9004
    Parking Light Bulb Size: 4157NALL
    Front Turn Signal Light Bulb Size: 4157NALL
    Rear Turn Signal Light Bulb Size: 3156
    Tail Light Bulb Size: 3057
    Stop Light Bulb Size: 3057
    High Mount Stop Light Bulb Size: Assembly
    License Plate Light Bulb Size: 168
    Back Up Light Bulb Size: 3156
    Front Sidemarker Light Bulb Size: 194
    Ash Tray Light Bulb Size: 558
    Glove Box Light Bulb Size: 194
    Map Light Bulb Size: 168
    Dome Light Bulb Size: 562
    Step/Courtesy Light Bulb Size: 168
    Trunk/Cargo Area Light Bulb Size: 212-2
    Daytime Running Light Bulb Size: 3157NALL
    Thank you for using fixya.
    Apr 30, 2010 | 2000 Pontiac Montana
    How do you take out light ballbs from dacor hod fan
    To replace the light bulb:
    1. Remove the right filter and turn off the main power
    switch.
    2. Gently push the suction cup on the light replacement
    tool A (provided with you range hood)
    onto the lens of the light bulb B .
    3. Turn the tool counter-clockwise until the bulb
    comes loose.
    4. Remove the tool from the bulb and put it on the
    lens of the replacement bulb.
    5. Screw the new bulb into the light fixture clockwise
    until it is tight. Turn on power at the fuse or junction
    box. Turn on the main power switch and touch
    the light key to make sure it is working.
    6. Replace the filter.
    You can download the manual here.
    Good Luck And please Rate FixYa!
    Dec 19, 2008 | Dacor EHD3618SS Kitchen Hood
    How to replace headlight on a 2003 Chevy Tracker
    There are two black plastic clips behind the the air filter, remove them and release the whole assembly to access the lights.
    If you still get in troubles, have it replaced at a petrol station, they will help you in fitting the bulb, and it won't be expensive.
    Here follows
    2003 Chevrolet Tracker Light Bulb Size Chart
    Low Beam Headlight Bulb Size: 9003/HB2
    High Beam Headlamp Light Bulb Size: 9003/HB2
    Parking Light Bulb Size: 1157A
    Front Turn Signal Light Bulb Size: 1157A
    Rear Turn Signal Light Bulb Size: 921
    Tail Light Bulb Size: 7443
    Stop Light Bulb Size: 7443
    High Mount Stop Light Bulb Size: 168 Or 921
    Back Up Light Bulb Size: 921
    Ash Tray Light Bulb Size: 74
    Trunk/Cargo Area Light Bulb Size: 168
    Instrument-General Light Bulb Size: 158 or 74
    Check Engine Indicator Light Bulb Size: 74
    Hi-Beam Indicator Light Bulb Size: 74
    Seat Belt Indicator Light Bulb Size: 74
    Brake Warning Light Bulb Size: 74
    Automatic Transmission Indicator Light Bulb Size: 74
    Directional Signal Indicator Light Bulb Size: 74
    Oct 02, 2008 | 2003 Chevrolet Tracker
    ViewSonic PJD6241 3D DLP Projector Logo
    20 people viewed this question
    Top ViewSonic Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
