Martin invented gas stove mdl. AU40D/U40G/U40F
Martin invented gas stove mdl. AU40D/U40G/U40F pilot lights but will not stay lit already replaced thermocouple how do I check the low oxygen cutoff
Buffalo12980
  • 625 Answers
SOURCE: Pilot light lit but no heat
the pilot's millivolt generator may be at fault.  if you have a meter that is capable of measuring a very small DC voltage, connect it up to the very end of the thermocouple and the copper cappillary. the thermocouple has a welded bead at the very end inside that generates a small DC voltage. Same principle of a J-K thermocouple. Iron constintan  - two dissimiller metals where joined together produce a voltage when heated.  the thermocouple actuates a millivolt electromagnet inside the valve to keep the valve pellet open.  no voltage there it won't actuate the electromagnet.
Posted on Oct 15, 2007
  • 3315 Answers
SOURCE: Pilot light does not reach thermocouple
the pilot oriface is blocked it needs cleaning out ,
Posted on Jan 14, 2009
  • 1214 Answers
SOURCE: pilot wont stay lit installed new gas valve and new thermocouple
Is this a standing pilot furnace, or electronic igniton?
If standing pilot, does the heater use a fan to blow air through the heat exchanger?
If the answer to those questions is yes, then check that the pilot orifice is not partially plugged and that there is a strong pilot blowing against the thermocouple. If there is, replace the thermocouple. If not, check the orifice again, and check that the inlet screen to the gas valve is not filled with gas line trash.
If the the pilot flame is good and it continues to go out, the thermocouple magnet in the gas valve may be weak. Replace the gas valve as to get just the magnet and coil is not easy.
Reply back any questions you may have.
Posted on Jan 28, 2009
  • 3315 Answers
SOURCE: Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Posted on Feb 07, 2009
  • 3315 Answers
SOURCE: cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Posted on Feb 24, 2009
I need help finding a regulator for a Martin natural gas Model number AU40D. Any suggestions??
A regulator is mostly a fairly general item any local heating engineer should be able to supply, rather than a spare part for a particular appliance.
Oct 23, 2017 | Pool & Spa
Heater serial # 3687823 was working fine then just stopped. cant get it to light now
if the pilot lights when held but wont stay lit, the thermocouple is shot, local hardware stores sell universal thermocouples. self explanatory to replace. if even when pressing the button the pilot doesn't light there is a blockage in the gas line or control valve. that needs a pro to fix.
Mar 16, 2014 | Procom Heating & Cooling
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
Pilot lights will not stay lit on stove top or oven. Can light burners with match. Crosley c3100paw
You need to clean thermocoupling off it what the pilot lit uses to stay lit. you canuse sand paper or brush May need to replace, clean gas tubes on pilot also could be that
Dec 12, 2011 | Crosley Kitchen Ranges
My Pyromaster Gas Fireplace Pilot will not stay lit
Try cleaning the thermocouple with sandpaper or wirebrush. Sometimes it gets dirty and doesn't sense the flame.
Dec 11, 2010 | Stoves Heating & Cooling
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
