It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
YOUR
SAFETY IS PARAMOUNT
This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the
!!!!capacitor is discharged!!!!! before attempting any
sort of repair.
Check the door interlock switches first then the
high voltage diode with either an AVO model 8 or moving coil meter on
high resistance range for short circuit, (DVM's won't show the
fault!), the capacitor can fail and go short circuit, the feed fuse
on the primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
Load
test.
A
simple safety test.
Place 1/2 litre of water in a glass container.
Measure the temperature of the water.
Place in microwave and heat
on full power for 1minute.
Measure the temperature after it has
stood for 1minute.
If the temperature difference is more than 9
degrees Celcuis the magnetron is working and producing about 700Watts
of heat.
If your microwave is labelled with 900 or 1000Watts. That
is about right.
If the temperature is less then the magnetron is
not working properly and may need replacing.
This
a only a rough guide and any doubts you should consult an authorised
service agent.
