Question about LaCie (300770) 250 GB Hard Drive
Drive mysteriously went from 250GB to 55MB!?
Is there a way to reformat the drive and start from scratch? A friend gave this thing to me because he gave up trying to figure out why it freaked out. When I look at disc properties it says there is only 55MB disc space total. What the heck happened to the other 249.945GB?? Lacie is completely unresponsive to questions regarding this problem... Thanks.
    Brigadier General:
  • 6,966 Answers
Hi, It would seem that the LaCie(300770) 250 GB Hard Drive would need partitioning and not only formatting to be able to recover the missing space. This is better explained by Microsoft Support . Alternately, you can right click on "My Computer, click on Manage, click on Disk Management, right click on the Lacie drive and delete its current partition. Ok or Apply, Windows may ask you to reboot. Do the Disk Management again. If the Lacie's original/erroneous partition has been successfully deleted, it will now show as "Unknown Partition". To create your new partition, right click on the unallocated space (black stripe on top), click on "New Partition" on the menu. To format, simply right click on the Lacie and click on Format. As a matter of choice, I prefer to use Partition Magic and/or Seatools for Windows. If using any of the above method and the Lacie will not partition/format or errors keep on appearing, it may be that the Lacie is no longer usable as a whole. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 27, 2007
SOURCE:
My Toshiba 250gb external hard drive model hddr250e03x is not recognized by my macbook pro but the light turns on. It works on my friend's macbook pro but not mine
I'm assuming you mean it doesn't appear in Finder. Open up disk utility and it should appear there if you say the MacBook is providing power to the hard drive light. You may have to reformat or reset your Mac if you want it in finder
I’m happy to help further over the phone at https://www.6ya.com/expert/tarik_f88885a87e319a0d
Oct 14, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
Dell error code 0f00 1322
The drive is bad and will only get worse.
Momentus 250GB 5,400 RPM SATA 3.0Gb/s 2.5" Internal Hard Drive ST90250N1A1AS-RK $50
for more help visit Cbr tech solutions
Jan 15, 2013 | Computers & Internet
Unlock a wd scorpio black 250gb
I would just delete any partitions and format. Hard drives are extremly hard to lock down, especaily after connecting on a differnt machine.
Insert the Window install disc and boot from to do a clean setup, instead of going through Windows.
Dec 31, 2012 | Western Digital 250GB WD Scorpio Black...
I transferred a 40gb hard drive onto this 250gb go flex drive and then transferred it back. Now when I try to tranfer anything else to this drive, it only allows 40gb of space to transfer. I reformatted...
my computer does not read or detect my hard drive no matter what i do, and when it does read from the drive it does not upload to the computer. so what shall i do?
Jan 25, 2011 | Seagate O 250Gb Usb20 Freeagent Go Silver...
Wants to reformat drive when trying to access.
Install the drive as a secondary drive on known working computer. Go into it via windows explorer, locate and backup the files you want on a usb stick or external hard drive. Format the drive, load your OS, and reinstall the files you saved from the drive before you formatted it.
Apr 10, 2017 | Buffalo Technology 250GB USB SATA 2.0 HD...
Reformatted my external hard drive on accident
If formatting is not working, means there is some problem in the data segments of the disk.
thanks,
saumya.
Aug 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
When I plug the Toshiba 250GB into the PC nothing happens
ok to solve this is a little complicated so first you need to click star the on your mouse right click on computer and then say manage
you should then look to the left of the window someware there you should see something that says disk manger in the categories there you should see a second drive or you might see 3 depending on if you have a recover drive. these are the drives you don't mess with c:/ or D:/ so look for your drive in the list and right click on it and say format if you have any question then comment hope this helps warning formating you drive will erase everthing on it
Jul 28, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Mysteriously dissapearing files
hi,
your folder has been secured by a virus. donot format the drive or you will lose the info. look for a data recovery software and run data recovery on that partition of the disk to recover the corrupted files
thanks
Nov 24, 2008 | Buffalo Technology 250GB MINISTATION TURBO...
Lacie 250GB External Hardive to be used between a PC and a MAC
Be carefull when moving data from Macs to Windows etc. Your best bet would be to start again. It should work if you get your friend to put the data on the drive & copy it directly to your Mac. From there, you can safely copy data to the PC, but may have trouble accessing that same data after the PC has had it.
Jul 31, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
LaCie (300770) 250 GB Hard Drive Logo
431 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
