Hello I have a problem to my IR 2420 when I turn on the machine this message appears 'restart the machine if the problem still persists contact to local authorized **E000007-0000' please tell me how I can solve this problem. Thanks
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
hi how do solve this problem system error E007
Posted on Apr 09, 2009
redzventures
  • 149 Answers
SOURCE: I have an IR-3300 Model xerox machine. It was
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
Posted on Jul 31, 2009
canontech
  • 1219 Answers
SOURCE: hello can somebody help me about the problem of my
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
0002 The next HP fails to be detected within
the specific period of time after the HP
of the ITB is detected.
Clean the ITB back side and the drive roller
0003 The next HP is detected earlier than the
specific period of time after the HP of
The ITB is torn due to scratches, and the
sensor detects the tear as a HP by
mistake
sensor
Posted on Jun 16, 2010
  • 47 Answers
SOURCE: Hi, I have a "dead"
APP position error or Error Code 6A80
Condition: An error occurred in the APP motor.
Problems and Solutions:
  • Check for foreign material or paper debris around the purge drive system unit
    - remove foreign material.
  • Check for foreign material or paper debris around the ASF unit
  • If other solution fail, replace one off the following part
    - Purge drive system unit
    - Logic board
for more info visit: http://pcmediks.blogspot.com
Posted on Dec 28, 2010
I have IR Canon 2420 copier machine it shows E000007-0000 please help me what is the problem Thank yoyu
as the error codes are cannon specific I suggest that you contact a canon service dealer and ask them what the codes mean
Sep 03, 2015 | Canon Office Equipment & Supplies
Code Error on Ir 2420 l display **E000003-0000 what can i do please solve this...
dear
pl. do check the fixing film assy. heater strip contact points. if corrosion clean/replace it.
Check the DC card.
Also check the supply voltage at the machine input.
Thanks.
Dec 04, 2014 | Canon Office Equipment & Supplies
In my canon xerxo imagerunner IR2420L displays error massege "restart your the machine, if the problem persist call service rep. **E00010-0000" So plz help if u have the solution.
Hi Suvra,
Error code E0010-xxxx indicates that main motor rotation error. Unfortunately, i am not familiar enough with this machine. You should find the main motor location in your copier and check whether it works properly or not.
I found the link to service manual on the web. If you don't mind to spend little money i think the following link will be useful for you. :)
Canon iR 2422 2420 2320 2318 Service Repair Manual Parts Catalog...
Jan 11, 2014 | Office Equipment & Supplies
E000808 0000
Please What can the solve of Problem Restart the machine if problem persists call service rep. error message : E000808-0000 model canon ir 2420L
Nov 30, 2013 | Computers & Internet
What is remedy error code E000007-0000 for canon imageRUNNER 2422/2420
A E000007-0000 means that the fixing film is out of "HP" The fixing film has a white patch that is the home position and as the film is turned, there is a sensor that reads it in & out of "HP". Odds are that the film is ripped on one side and the film moved toward the front of the copier and the sensor can not read the patch. You will need to replace the upper film unit or the whole fuser unit to repair the problem.... Good Luck
Sep 18, 2012 | Office Equipment & Supplies
Error code 490665 van HP Laserjet 2420
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred.
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off, and then
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2420.
Click Download Drivers and
Software. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
4. Try printing a job from a
different software program. If
the job prints, go back to the
first program and try printing a
different file. If the message
appears only with a certain
software program or print job,
contact the software vendor
for assistance.
If the message persists, try this:
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Jul 11, 2011 | HP LaserJet 2420 Printer
Continue loading error ir1022 dn't stopped
hi. you need to enter in service mode.
press aditional function
press 2
press 8
service mode should appear in the screen . with the arrow search for CLEAR
press ok and now with arrows search for ALL press ok
machine should restart.
if problem persist maybe a software upgrade is required ( technical service ) if problem persist after upgrade . you need to replace the image processor board.
May 06, 2010 | Canon Office Equipment & Supplies
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Jul 23, 2008 | HP LaserJet 2420 Printer
22 people viewed this question
k24674
jasbo
jasbo
