Question about Adesso WKB-1000SB
How can I sink my keyboard to my tablet ? - Adesso WKB-1000SB
Do i need other cord to connect keyboard
keyboard connected to a tablet ? there are only two ways I know of doing this , one is if tablet has a usb port and you have a usb keyboard (keyboard gets its power from same port) or second way is to use Bluetooth keyboard (if tablet has blutooth) keyboard gets its power from internal batterys and has a power switch then
Jul 28, 2016 | Tablets & eReaders
Keyboard will not work
Dawn,
IF your tablet and keyboard work with "Bluetooth" then check under you tablets settings page (look for Bluetooth) it may have been turned off.
IF your tablet/keyboard does not used Bluetooth, check the battery in the keyboard, It may have been depleted...
Does the keyboard have an OFF/ON switch, that my also be your issue.
Hope this helps.
Topbarhive
Jan 12, 2016 | Tablets & eReaders
I have an irulu 7" tablet that I got for Christmas. So far the tablet is working, however the keyboard case does not work when plugged into the USB port at the top of the tablet. It is my understanding...
Not sure on you particular model but most tablets have 2 mini USB ports one has a power supply and the other is just an I.O port .
Try your keyboard in the other port if you have one and it should work. If not it may be faulty.
HTH
Jan 01, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
I have a kocaso tablet. Model #m752h. What settings do I use for the keyboard case?
I am not sure if you need a specific setting to use the keyboard or if your tablet will recognize it once you connect the keyboard to the tablet. To connect the keyboard to the tablet use the USB cable or the OTG cable that came with the tablet. I cannot give you specifics on how to connect because I am not familiar with that tablet, but you can read the instructions in the user's manual of your tablet. I am also providing some links to help you.
How to Connect Mice Keyboards and Gamepads to an Android Phone or Tablet
Connect USB Keyboard on Android Smartphone or Tablet via USB OTG
Clever adapter connects USB accessories to your Android device CNET
Dec 24, 2014 | Tablets & eReaders
How do I connect the keyboard to the tablet
Via Bluetooth. I assume your keyboard is a Bluetooth keyboard, as this is the only type of keyboard you can connect to a tablet or mobile phone. Follow the instructions on the set up guide that came with the keyboard.
Dec 12, 2014 | Hipstreet EQUINOX 2 10.1" Wi-Fi Capacitive...
My keyboard will not work on my new visual land prestige elite
1. If your keyboard is not Bluetooth-enabled, it will never work with your tablet.
2. If your keyboard is Bluetooth-enabled but your tablet is not, it will never work with your tablet.
3. If both your keyboard and your tablet are Bluetooth-enabled, connect your keyboard to the tablet using Bluetooth as per the set up instructions that must have come with the keyboard.
Nov 22, 2014 | Visual Audio Players & Recorders
Microsoft bluetooth mobile keyboard 6000
Wireless keyboards connect to tablets using Bluetooth, a wireless technology with a short range of only about 30 feet.
In most cases, you can prepare a keyboard to connect with a tablet simply by turning the keyboard off, then turning it on again while it is close to the tablet.
Read the instructions that came with the keyboard to see if it requires a passkey to connect with a device.
The passkey ensures that your keyboard is not accidentally connected to another nearby device. The steps required to connect a tablet to a wireless keyboard can vary slightly depending on the tablet's operating system.
Unlike docked keyboards, a wireless keyboard does not have to be designed for your specific tablet for it to be usable.
Turn on the keyboard and put it in discovery mode.
Place it near the iPad.
Tap the "Settings" icon, then tap "General."
Tap "Bluetooth" if it is in the Off position.
Tap the "On/Off" switch to turn it on.
Choose the wireless keyboard when it appears on the screen. Enter a passkey for the keyboard if prompted.
The keyboard name and a Bluetooth icon appear on the screen.
BlackBerry PlayBook Tablet
Turn on the Bluetooth keyboard and put it in discovery mode before placing it near the tablet.
Tap the "Settings" icon on the tablet status bar, then tap "Bluetooth."
Tap the "Bluetooth" switch to choose the "On" position.
Tap "Add New Device," then select "Search."
Wait a few seconds for the keyboard to appear.
Enter the keyboard passkey if prompted.
Samsung Galaxy Tab (Android)
Turn on the wireless keyboard and put it in discovery mode.
Place it near the tablet.
Navigate to the Home screen. Press the "Menu Key," then select "Settings."
Tap "Wireless and Network," then "Bluetooth Settings."
Tap "Bluetooth" to turn it on, then tap "Scan Devices."
Select the keyboard by tapping it.
Enter the passkey if prompted.
HP Slate (Windows)
Turn on the wireless keyboard while it is near the tablet, then put it in discovery mode.
Tap the Start button, then "All Programs."
Tap "HP," then "HP Connection Manager."
The device searches for nearby devices and lists them.
Locate the keyboard in the list, then tap the "Power Button" beside the keyboard entry.
Enter a passkey if prompted.
http://bluetooth.org/
Jun 29, 2013 | Microsoft Bluetooth Mobile Keyboard 6000
How do you turn off the lenovo thinkpad tablet 2 keyboard?
You turn the power off to the Thinkpad Tablet 2 keyboard by holding the power switch to the right for 3 seconds.
Mar 05, 2013 | Lenovo ThinkPad Tablet 2 Bluetooth...
I need to know where the processor is located so it can be replaced
The CPU is located under the fan and heatsink assembly.
Mar 12, 2011 | HP Tablets & eReaders
Adesso WKB-1000SB Logo
26 people viewed this question
Top Adesso Computers & Internet Experts
Chris Benedict
Level 1 Expert
ray gallant
Dougie
Are you an Adesso Computer and Internet Expert? Answer questions, earn points and help others
