Question about Panasonic Viera TH-42PX80U Plasma TV
Panasonic TC-P65ST30 has a solid black bar 3 1/2 inch wide 7 1/2 inches from right side of screen. Could it be the C-1 board?
2 Suggested Answers
gopakumarg43
  • 74243 Answers
SOURCE: What is causing a 6 inch vertical black bar on left side (only) of panasonic TC-P65ST30
The X-Sustain board has the fault I presume. Just visit this site, named 'Electro-help'. This type of fault, and its repair proceedings are detailed there with illustrations. Check this link and select the site. Pull up older posts there. Sometimes, ads attached with each posts there might give you details of the components availability too.
Posted on Jul 19, 2012
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
May 22, 2015 | Televison & Video
65" Panasonic has 4" vertical black bar!!
By your detailed description, it sounds that there should be a loose connection with the 'COF'; connected to the screen. All of these COFs, can be located at the bottom side of the screen [looking from back]; in a horizontal row. If you wish to get more details to this fault, check the site kinked here. It has screen-shots of defective plasma TV screen, and possible faults.
I should appreciate you for this detailed description, that a few users will provide.
Try this link. Pull up older posts. If you wish to get more assistance from me, feel free to come over by Fixya comments.
Nov 24, 2013 | Panasonic Viera Tc - P65S2 65 inch 1080P...
Problem rolling bars
It should be a main power regulator baord fault. Contact any service technician.
May 22, 2013 | Panasonic TCP50U2 50 in. TV
Jul 19, 2012 | Panasonic 65 TCP65ST30 3D Plasma TV
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Apr 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic Viera TH-42PX80U Plasma TV Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
