Question about LG Washing Machines
Replacement or adjustment of drive belts how to do it?
    Master:
  • 818 Answers
Http://www.youtube.com/watch?v=X1yY_6vKK8g watch this video-it should help-cheers Denny
Posted on Oct 19, 2013
Yth2248 loses speed on slightest grade. new drive belt not helpful
Roy if it is the correct belt and fairly new, check your manual for belt adjustment, if it shows that there is no adjustment the pulleys may be worn out, on a lot of mowers the pulleys are ware items and changed more often to correct slipping issues. The other thing to check is the belt tensioner if equipped, it could be seized, weak or missing spring or it may even be adjustable by cable end being threaded or slotted bolt holes on tensioner arm.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Drive Pulley Replacement On Craftsman Lawn Tractor
Mower Engine Pulley Replacement Craftsman Riding Lawn Mower Repair Part...
Cub Cadet LT1045 Transmission Drive Belt Replacement
husqvarna LGT24k54 drive belt install
Apr 22, 2016 | Garden
How to change drive belt
  1. Step 1 - Loosen tension and remove belt. Locate the adjustment fastener and loosen it. ...
  2. Step 2 - Inspect drive and drive pulleys. Check the drive and pulley wheels. ...
  3. Step 3 - Select correct replacement belt. ...
  4. Step 4 - Install V-belt. ...
  5. Step 5 - Correctly tension new belt. ...
  6. Step 6 - Start the engine.
Mar 24, 2016 | Huskee Tractor Replacement Riding Lawn...
2005 xl7. How can I adjust alternator?
remove battery neg lug first. do not yank off alternator wires! until
this step is done first, or boom fire or eat acid.
which engine, we cant guess them here.
my guess H27 v6, wrong the 3.6L
all belts covered on car. (accessory)
here is a real 2007 page
seem you get lost at step 7
right>?
26044119-eqsv1nhxqdz21u4tq0h4adgz-1-0.jpg the alternator is NOT adjustable
so why ask this?
the $4 FSM covers this.
under drive belt replacement.
Removal Procedure
Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
Install the engine support fixture. Refer to Engine Support Fixture .
Remove the engine mount strut bracket. Refer to Engine Mount Strut Bracket Replacement - Right Side .
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the engine splash shield. Refer to Engine Splash Shield Replacement - Right Side .
Remove the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Lower the vehicle.
Rotate the drive belt tensioner clockwise to release the drive belt tension.
Slide the drive belt off of the belt idler pulley (1).
Slowly release the drive belt tensioner.
Remove the drive belt from the accessory drive pulleys.
if the post was to remove alternator? is it
do above
then unbolt alt.
end guessing what you are doing....
Jan 08, 2016 | Suzuki Cars & Trucks
How to remove belts from 1994 dodge caravan 2.5 liter
Drive Belts
Print
INSPECTION
See Figures 1, 2, 3, 4 and 5
Check the condition and tension of all drive belts every 12,000 miles, or at least once a year. Loose drive belts can lead to poor engine cooling and diminished alternator, power steering pump, air conditioning compressor, or emission air pump output. A belt that is too tight places a strain on the bearings in the driven component.
Fig. Fig. 1: There are typically 3 types of accessory drive belts found on vehicles today
Fig. Fig. 2: An example of a healthy drive belt
Fig. Fig. 3: Deep cracks in this belt will cause flex, building up heat that will eventually lead to belt failure
Fig. Fig. 4: The cover of this belt is worn, exposing the critical reinforcing cords to excessive wear
Fig. Fig. 5: Installing too wide a belt can result in serious belt wear and/or breakage
Replace any drive belt that is glazed, worn, cracked, or stretched to the point where correct adjustment tension is impossible. If two belts are used to drive a component, always replace both belts when replacement is necessary. After installing a new belt, run the engine for ten minutes, shut OFF the engine and recheck the belt tension. Readjust if necessary.
ADJUSTMENT
See Figures 6, 7, 8, 9 and 10
Fig. Fig. 6: Engine belt tension chart-2.2L engines
Fig. Fig. 7: Engine belt tension chart-1987-89 2.5L engines
Fig. Fig. 8: Engine belt tension chart-2.6L engines
Fig. Fig. 9: Engine belt tension chart-1990-93 models
Fig. Fig. 10: Engine belt tension chart-1994-95 models
Two popular methods of checking drive belt adjustment are; the Belt Tension Gauge Method and the Belt Deflection Method. The former requires a special gauge and the latter requires a straight edge and scale or just a good eye for measurement. The deflection method will be used in the following belt replacement instructions. A rule of thumb for checking belt tension by the deflection method is to determine the midpoint between two pulleys of the drive belt and press down at that point with moderate thumb pressure. The belt should deflect to the measurement indicated in the following installation procedures. Adjustment is necessary if the belt is either too loose or too tight.
WARNING A belt adjustment which is either too loose or too tight will eventually damage the accessory that belt is driving. A too loose adjustment allows free-play in the belt which could transfer a whipping motion or shock to the accessory drive pulley. Similarly, a belt which is too tight will preload the accessory bearings, leading to early failure.
REMOVAL & INSTALLATION
See Figure 11
Raise the front of the vehicle, support on jackstands and remove the lower splash shield if access is hampered due to space limitations when changing drive belts.
Fig. Fig. 11: Support the vehicle, then remove the lower right side splash shield for access to the drive belts
2.2L Engines
A/C COMPRESSOR DRIVE BELT
See Figures 12, 13 and 14
Fig. Fig. 12: A/C compressor drive belt adjusting points-2.2L engines
Fig. Fig. 13: Loosening the locking screws for A/C compressor drive belt removal
Fig. Fig. 14: Removing the A/C compressor drive belt from under the vehicle
  1. Loosen the idler pulley bracket pivot screw and the locking screw.
  2. Remove the belt and install a replacement.
  3. Using a breaker bar and socket apply torque to the welded nut provided on the mounted bracket to obtain proper tension.
  4. Tighten the locking screw first, followed by pivot screw. Tighten to 40 ft. lbs. (55 Nm).
ALTERNATOR DRIVE BELT (CHRYSLER TYPE)
See Figures 15 and 16
Fig. Fig. 15: Alternator belt adjustment-2.2L engine
Fig. Fig. 16: Loosening the locking screw for alternator drive belt removal
If removal of the alternator belt is required, the A/C belt must first be removed.
  1. Loosen the pivot nut, locking screw, and the adjusting screw.
  3. Adjust to specification by tightening the adjusting screw.
  4. Tighten the locking screw to 25 ft. lbs. (34 Nm).
  5. Tighten the pivot nut to 30 ft. lbs. (41 Nm).
ALTERNATOR DRIVE BELT (BOSCH TYPE)
  1. Loosen the pivot nut, locking nut, and adjusting screw.
  4. Tighten the locking nut to 25 ft. lbs. (34 Nm).
POWER STEERING BELT
If removal of the power steering belt is required, the A/C and alternator belts must first be removed.
  1. Loosen the locking screw, and pivot screw.
  3. Install a 1 / 2 in. breaker bar into the pump bracket slot, apply pressure with the breaker bar and adjust the belt to specification.
  4. Tighten the locking screw first, then the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
AIR PUMP DRIVE BELT
See Figure 17
Fig. Fig. 17: Air pump belt adjustment-2.2L engines
When servicing the air pump, use the square holes provided in the pulley to prevent camshaft rotation.
  1. Remove the nuts and bolts retaining the drive pulley cover.
  2. Remove the locking bolt and pivot bolt from the pump bracket, then remove the pump.
  3. Remove the belt and install a replacement.
  4. Position the pump, then install the locking bolt and pivot bolt finger-tight.
  5. Install a 1 / 2 in. breaker bar into the bracket assembly (block the drive pulley to prevent camshaft rotation), and adjust the belt to specification.
  6. Tighten locking bolt and pivot bolt to 25 ft. lbs. (35 Nm).
2.5L Engines
AIR CONDITIONING COMPRESSOR
See Figure 18
Fig. Fig. 18: Drive belt adjustment points-2.5L engines
  1. Loosen the idler bracket pivot screw and the locking screws to replace, or adjust belt.
  3. Adjust the belt to specification by applying torque to weld nut on the idler bracket.
  4. Tighten locking screw first, followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
ALTERNATOR BELT
See Figure 18
If replacement of the alternator belt is required, the A/C drive belt must first be removed.
  3. Adjust the belt to specification by tightening the adjusting screw.
  4. Tighten the locking nut to 25 ft. lbs. (35 Nm).
  5. Tighten the pivot nut to 30 ft. lbs. (40 Nm).
POWER STEERING PUMP
See Figure 18
If replacement of the power steering belt is required, the A/C and alternator belts must first be remove.
  1. Loosen the locking screw and pivot screw to replace, or adjust the belt.
  3. Using a 1 / 2 in. breaker bar positioned in adjusting bracket slot, adjust the belt to specification.
  4. Tighten the locking screw followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
2.6L Engines
ALTERNATOR/AIR CONDITIONING COMPRESSOR BELT
See Figure 19
Fig. Fig. 19: Drive belt adjustment points-2.6L engines
  1. Loosen the locking screw, jam nut, and pivot nut.
  2. Loosen the adjusting screw.
  4. Adjust the belt to specification by tightening the adjusting screw.
  5. Tighten the locking screw followed by the pivot nut. Tighten to 16 ft. lbs. (22 Nm).
  6. Tighten the jam nut to 21 ft. lbs. (28 Nm).
POWER STEERING PUMP BELT
See Figure 19
If replacement of the power steering belt is required, the alternator and A/C belt must first be remove.
  1. Loosen the pivot screw, and the locking screw.
  2. Remove the timing pickup.
  4. Install a 1 / 2 in. breaker bar in the adjusting bracket slot, torque to specification.
  5. Tighten the locking screw, followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
  6. Install the timing pick-up, and tighten to 160 inch lbs. (18 Nm).
Jul 26, 2012 | 1994 Dodge Grand Caravan
Replacement belt loose
There is an adjuster for both drive belts which may be there
Feb 29, 2012 | 2001 Subaru Outback
I need step by step instructions on how to install an alternator belt into a 1997 kia sephia. Also need a list of necessary tools
Welcome to FIxYa.com
GENERATOR DRIVE BELT INSPECTION
1. Check the drive belt and pulley for wear, cracks, and fraying. Replace if necessary.
2. Measure the drive belt tension with a tension gauge.
Tension lb (N)
3. Measure the deflection by applying moderate pressure (221b,[9S N]) midway
between the pulleys. Adjust if necessary.
Deflection lb (N)
Adjustment
1. Loosen the generator mounting bolt and adjusting bolt.
2. Deflect the generator to achieve the specified deflection.
3. Tighten all bolts and recheck the tension.
Replacement
1. Remove the A'C and PS drive belt, if equipped.
2. Loosen the generator mounting bolt and adjusting bolt.
3. Remove the generator belt.
4. Install the new generator belt and adjust it to specification.
5. Tighten all bolts to the specified torque.
Tightening torque:
Mounting bolt:
2 7-38 ft-lb (37-52 Nm)
Adjusting bolt:
14-19 ft-lb (19-25 Nm)
6. Install the AC and PS drive belt: if equipped. and adjust to specification.
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 17, 2010 | 1997 Kia Sephia
How to change alternator belt
alternator and air conditioning compressor
  1. Disconnect the negative battery cable.
  2. Loosen the idler pulley bolt.
The replacement of the inner belt on multi-belted engines may require the removal of the outer belts.
To replace a drive belt, loosen the adjusting and mounting bolts of the component which the belt is driving. Move the component inward to relieve the tension on the drive belt.
Slip the belt off the component pulley and match the new belt with the old belt for length and width. The old belt will be slightly longer. After a new belt is installed correctly, adjust the tension.
  1. Turn the adjustment bolt at the top of the idler pulley bracket. Clockwise rotation will tighten the belt; counterclockwise will loosen it.
  2. Keep the idler pulley bolt snug (but not tight) while adjusting belt tension. The adjustment bolt should turn with moderate force.
After adjustment is satisfactory, tighten the idler pulley bolt, and then tighten the adjustment bolt.
Reconnect the negative battery cable.
When replacing more than 1 belt, it is a good idea to make note or mark what belt goes around what pulley; this will make installation easier if you mix up the belts.
Sep 25, 2010 | 1997 Nissan Maxima
Belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Feb 20, 2010 | Proform CrossTrainer Treadmill
1998 Dodge Avenger serpentine belt issue
What size of motor, do you have a/c and which belt are you replacing? Not sure about your engine size since you did not list it so please pick the applicable motor:
Sebring Coupe And Avenger (2.5L VIN N Engine)
  2. Loosen the tension pulley locknut.
  3. Rotate the adjusting bolt to decrease the belt tension.
  4. Remove the drive belt from the engine.
To install:
  1. Position the replacement belt around the pulleys, making sure the belt routing is correct.
  2. Adjust the belt by rotating the adjusting bolt until the correct tension is reached. Refer to the procedure earlier in this section for belt adjustment.
  3. Once the desired tension is reached, secure the locknut. Recheck the belt tension.
  4. After the belt is installed and adjusted properly, tighten the locknut to 17 ft. lbs. (23 Nm).
  5. Connect the negative battery cable.
2.0 DOHC
Power Steering Pump And A/C Belt
To install:
  4. After the belt is installed and adjusted properly, tighten the locknut.
Oct 29, 2009 | 2000 Dodge Avenger
Drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Mar 29, 2009 | Garden
Washing Machines Logo
18 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
