SOURCE: ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
SOURCE: Ge Profile Electric dryer model DPSE810EG5WT The
Hi.
If the fan does not work at all,then the fan motor must be replaced. The fan is tested jumping its contacts to energize it directly.
More commonly the problem is clogged air ducts. Check lint filter and check ducts for blockage. Ensure that the air duct is well in place.
SOURCE: How to disassemble a GE Profile Electric Dryer model# DPVH880EJMG
the element is usually located on the bottum rear of the dryer. there should be access in the rear or the entire front comes of wit a coulpe of screws from below the door and then it will be under the drum. hope this helps
