Question about Troy Bilt Tb70ss Gas Trimmer
Replaced pull rope with new one now when you pull rope it will not recoil all the way
    New Friend:
    Problem Solver:
  • 5 Answers
There are 2 ways that u can fix that problem. First u .cn leave the tention u have on it now and shorten the rope or u can tighten the recoil spring more and that will take care of it.
Posted on Oct 19, 2013
How do I replace the starter (pull) rope on a toro ccr2450 (model 38413)?
Although it looks like you simply un-bolt the recoil starter you need remove the whole blower (flywheel) housing as there are nuts on the back side.
  • Once the housing is off, remove the broken rope and prepare a length of rope to replace it base upon the old ropes length. Probably close to 6 feet.Don't forget to put the pull handle on the new rope.
  • Tighten the recoil pulley in the direction it normally turns as you pull the rope out until it stops.
  • Slowly back of up to one turn to align the hole in the pulley with the housing hole and hold it in that position while you insert the rope and try a sturdy knot.
  • Slowly let recoil assembly pull the rope back in and test that it is working properly before re-installing the housing.
  • Once you are satisfied that the recoil is working properly re-install the remaining covers.
Jan 15, 2015 | Toro Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Broken pull chord
Remove recoil assembly from top of engine. Observe recoil wheel and find knotted end of rope in wheel, Observe direction of rope wrapped around wheel, cut knot off wheel end of rope remove rope. Rope purchased by the foot at mower repair shop. Feed new rope end into hole in recoil wheel wrap around in correct direction, feed rope thru recoil cover, remove old rope from handle, feed new rope thru handle to proper length, Knot rope to stay in handle.
May 14, 2012 | Toro Power Lawn Mower
How do I repair the pull cord on a masport 600 mower - the cord snapped when I was trying to start it.
Hi and welcome to FixYa, I am Kelly
- Remove the recoil assy. Depending on engine model you may hae to remove the air shroud with the recoil.
- Remove the broken rope assy from the spool by lifting the knot out of the hole and cut off the knot.
- Pull the remainder of the old rope out of the recoil spool
- Take the remainder of rope out of the pull handle
On the new rop burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end of the trheaded through rope.
- Pull very hard on the rope until the new knot seats in the handle. Assemble handle.
- PREWIND the spool in the recoil until it stops winding. I.e. max out spring tension but do not over wind it or you will break the spring. Make sure NOT to wind it in the wrong direction or you will break the spring
- Back off the spool until the knot hole is aligned with the rope guide bushing on the outside of the recoil.
- Either use a C-clamp or a 2nd person to hold the pre-wound spool in place.
-Thread the new rope through the outer rope guide and into then through the knot hole in the spool.
-Tie ONE small knot in the rope and pull it HARD back into the knot hole until the knot seats in the knot hole.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assy.
-reinstall recoil/air shroud on the engine.
That should get you mowing again.
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Briggs & Stratton Briggs Stratton...
The recoil spring on my 1986 victa lawn mower will not rewind the starter cord. Is this easy to fix?
- Remove the recoil assembly. Depending on engine model you may have to remove the air shroud with the recoil.
- Remove the broken rope assembly from the spool by lifting the knot out of the hole and cut off the knot.
On the new rope burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assembly.
Kelly
Dec 03, 2010 | Briggs & Stratton Garden
Homelite model No. 10609. 1H2100076 My pull rope won't recoil.
Not that i know of, take the cover off and rewind by hand, use greese on the coil and pull the rope in and out, if the rope doesnt recoil you are going to need a new pull start assembly
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
My lawnmower starter pull rope broke and i wanted to replace it myself to the something i can do myself. It is a craftsman 7.0 horsepower push lawn mower. Any body with step by step instructions and what...
The biggest thing you need is time. There are no special tools required but it sure helps of there are 2 people available to perform this task.
You will have to remove the recoil assy if it can be removed without the air shroud or the entire upper engine cover / air shroud with the recoil. This procedure should be performed by 2 people that are NOT distracted.
First you will have to have a replacement rope. Burn the end of the new rope your going to install into the spool and pinch it so that the end is smaller than the rope and pointed. Install the pull handle on the new rope and make sure there is a good single knot on the end of the rope that goes into the pull handle.
Next you will have to remove all pieces of the old starter rope.
Then you have to pre-wind the spring of the recoil so that if you were to allow it to turn, it would turn in a direction that would pull the starter rope onto the recoil spool.
NOTE: Once the pre-wind is done if anyone lets go of the spool it can DAMAGE the recoil spring!
When your prewinding... Turn the spool until snugs and does not want to move anymore. Then back off the spool until the rope KNOT hole is aligned with the recoil rope guide.
Thread the new rope through recoil rope guide and into the KNOT hole in the spool. (Ice pick scribe jewlers screwdriver... will be required to pull the new rope up and out through the knot hole. Then TIE a KNOT in the bitter end of the rope and pull the knot into the knot hole on the spool.
FINALLY have 2nd person release the spool and it will rewind onto the spool.
Install the recoil / air shroud.
Thanks for using FixYa.
Kelly
Feb 28, 2010 | YouTube Videos
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
How do you replace the starter cord for lawn mower?
Hi and welcome to FixYa. I am Kelly
You will have to remove the recoil assy if it can be removed without the air shroud or the entire upper engine cover / air shroud with the recoil. This procedure should be performed by 2 people that at NOT distracted.
Then you have to pre-wind the spring of the recoil so that if you were to allow it to turn it would turn in a direction that would pull the starter rope onto the recoil spool
NOTE: Once the pre-wind is done if anyone lets go of the spool it can DAMAGE the recoil spring When your prewinding... Turn the spool until snugs and does not want to move anymore. Then back off the spool until the rope KNOT hole is aligned with the recoil rope guide.
Thread the new rope through recoil rope guide and into the KNOT hole in the spool. (Ice pick scribe jewlers screwdriver... will be required to pull the new rope up and out through the knot hole. TIE a KNOT in the bitter end of the rope and pull the knot into the knot hole.
Kelly
Jan 20, 2010 | Poulan "Poulan" Push Mower
Troy Bilt Tb70ss Gas Trimmer Logo
73 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
