Question about Mitsubishi ES200U DLP Projector
Mitsibishi ES200U projector power board IC is fully damage, so i not know IC number. how to identify ic number plz help me....
  • 1153 Answers
SOURCE: No power
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) Hope this helps you!
Posted on Sep 14, 2007
  • 15 Answers
SOURCE: 3d look on mitsubishi ws-55511
Hi bluemags,
It is true that you should use a higher power I.C., I do that all the time. However, the one to use is the STK392-120. This one is rated at 5 Amps unlike the STK392-110, 150, which are both rated at 3 Amps. I have not checked the data sheet on the 180. They are all OEM, since Sanyo designed them all. Beware of generic knockoffs not made by Sanyo. The generic I.C.s do not have the quality as the Sanyo originals.
Best Regards,
MyTvGuy
Posted on Feb 10, 2008
  • 2318 Answers
SOURCE: Mitsubishi TV parts: IC
Check HERE for the DM power board.
Posted on Mar 04, 2008
  • 395 Answers
SOURCE: STK IC info
the convergance amplifiers are STK392-570 there are two of them they both must be replaced they are located on the power board. they are on the lagest heat sink on that board. yes, they need to be soldered to the board. they look like this:
70a4bc9.jpgthere also may be some resistors and fuses that failed. if you are not a tech do not attempt this repair if you do you may end up with further issues or dammage to you or the set.
Posted on May 26, 2008
  • 927 Answers
SOURCE: vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Posted on Nov 24, 2008
No Power
The problem may not necessarily be from the cable. It has to either be from the socket you plug it or the internal Power IC inside the projector. If your socket is working fine then you may have to take it to an experienced technical expert who will trouble shoot and diagnose the problem but since you said the projector is not powering, its likely the inbuilt power IC is damaged by maybe a surge in electrical current. Hope this helps... Cheers
May 06, 2013 | BenQ PB6210 Multimedia Projector
In asus P5GL-MX mother board the power supply regulator ic 2 piece has been damaged (short) how would i know plz help me
Hi if the regulator ic has been damaged in your power supply even you replace that there are some electronic component where also damage because the ic will not damage where there is no over voltage flow on it. This means there are some resistor or a transistor is also shorted it advisable to replace a new one than to repair your power supply. Because even you repaired it the performance and the life span of your power supply is not stable. So it better to replace a new one.
Jul 14, 2011 | ASUS P5GL-MX Motherboard
InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Jun 23, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
No power to Sony cs4
Ok - So i finally located the problem for the Stby lights not coming on......
Mine had the same procedure as all the other posting this - Could take up to 48 hours for the light to come on but this time only the whistling sound from the fan house on the front was present.
So i dissmounted the power supply located on a standing card at the back of the housing and found the faulty component :)
The solution for this problem is a IC in that board called IC MCZ3001DB changes this and all your problems with the projector not starting will be solved.
Oct 30, 2007 | Sony VPL CS4 Multimedia Projector
Dead
I called RCA today and they identify this part as IC 502 and the part number they gave me is 244662-U4(stock number),the phone number you need to call for parts is 1-800-338-0376,in this number they should give you price and availabity.I hope you can relate to the information.
Oct 13, 2006 | RCA BLC524 5.6 in. Television
Mitsubishi ES200U DLP Projector Logo
48 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
